Results 1 to 2 of 2
This is a discussion on Changing of Oil Brands within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Is it bad for the engine to change between two brands of oil (both still being the same weight and ...
    Tas
    Tas is offline
    Registered User Tas's Avatar
    Aug 2001
    Alexandria, VA
    Is it bad for the engine to change between two brands of oil (both still being the same weight and synthetic) often?
    Thanks,
    Tas
    "Never let school get into the way of your education."
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    I don't think that it would be very bad at all. Just make sure both oils are SAE approved for your vehicle and you should be set.
    I liken it to switching between Chevron and Shell every other fill-up. Your car shouldn't even notice.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
