They broke my bolts!
Results 1 to 15 of 16
This is a discussion on They broke my bolts! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok let me start this off with ERRRRRRR. God dam subaru. Ok so Im installing my Down pipe right now ...
    Registered User kram941's Avatar
    Jul 2005
    wilmington, MA
    Ok so Im installing my Down pipe right now and Im at the point of disconnecting the DP from the turbo and there it is...a bolt wit no head...looks like the people at subaru snapped it while they were installing it(unless its suppose to be like this) Well i hope it would come losse while i removed the nut but it didnt. Anyone have any suggestion on how to remove it? ill keep loadin it up wit WD40 while I wait for a response lol.
    EDIT: there are two bolts on the turbo like this!
    Registered User UR MOTHA's Avatar
    Dec 2001
    Fountain Valley, CA
    I think you're referring to the studs, they are supposed to be that way. 3 bolts will go into the turbo, 2 nuts will go onto the studs on the turbo.
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    Quote Originally Posted by UR MOTHA
    +1 if its on the turbo
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
    Jul 2003
    SOCAL!! 91752
    if its these 2 on the turbo. they are suppose to be there
    Dec 2001
    Fountain Valley, CA
    Quote Originally Posted by WRX13oy
    showoff
    Jul 2003
    SOCAL!! 91752
    showoff
    WORD! haha
    Jul 2005
    wilmington, MA
    haha few....thought i got totally screwed over
    Registered User speeddr2000's Avatar
    Mar 2005
    jacksonville
    so u didnt did relize it was a sud when u pulled a nut off it ? or was there no nut on it ?
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Aren't there 3 studs on the turbo?
    Jul 2005
    wilmington, MA
    Quote Originally Posted by speeddr2000
    I thought it was like the other two and it was a nut and a bolt so i thought the bolt head was broken off
    Jul 2005
    wilmington, MA
    Yea there was three studs on the turbo.
    finally got the DP installed took wayyyy to long lol... 2 hours to remove the bolt holdin it the to transmision. Had to cut the bracket the remove bolt it was so stuck. Just one leak tho caust i cant get the DP and exhaust to line up good enough(dam ebay) but gunna thro another gasket in there and that should do it.
    Mar 2005
    jacksonville
    did u tighten up the bolts in the right order there is an order i think is up to turbo then down pipe but i would check. if u dont tighten in the order u get a leak common problem.
    Jul 2005
    wilmington, MA
    So whats the correct order? I know i have a leak where the DP meats the rest of the exhaust...
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Yea I could swear there are 3 studs on the turbo and the only two bolts are on teh top that hold the heat shield bracket.
    As for the OP, did you install just the downpipe? Then there really isnt a correct order. The order that was spoken of a couple posts up refers to the uppipe installation.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    When the Subaru dealership replaced my clutch (because of the shudder), they cross thread one of the bolts. I had to cut the damn thing off. Thankfully it was one of the bolts and not the studs.
    Try not, do or do not. There is no try. - Yoda
    Mods
