Tricks for keeping our WRX's like new for life
Results 1 to 11 of 11
This is a discussion on Tricks for keeping our WRX's like new for life within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just recently (within the week) bought an 05 STI. Before i had a 98 Integra GSR that I just ...
    Registered User flipture's Avatar
    Jan 2006
    Atlanta
    I just recently (within the week) bought an 05 STI. Before i had a 98 Integra GSR that I just sold. I'm starting this thread because when I sold my GSR it would burn about 2 quarts of oil in a 2-3 week period. Now i'm DEATHLY scared of checking my oil and seeing it low like before. That is the main reason i sold the car. When I bought the GSR it did burn a little oil because the first time i changed the oil it was low. By the time i sold the car you could see the smoke coming out when at high RPM's.
    Now i believe this probably happened because it was a lease car at first and the first leasee(sp?) may have abused it and not taken it through the proper breakin periods knowing they wouldn't have to deal with the problems in the future. Basically i'm guessing they rhomped on it from 0001 miles through 5000 miles...
    For our cars, I've read that its a good thing to change the oil after the first 1k miles and keep it under 4k rpm or so for the first 5000 miles. Other than this what else can we do to ensure that our cars will last a good 250k miles without having to replace the rings or anythign else major like that? Besides drive it like a granny . I'm hoping to find a happy medium where i can drive my car pretty hard some of the time but be smart and keep it running like a champ for life...
    Hopefully we can get enough good information together to make this a sticky!
    Registered User le wagon's Avatar
    Jul 2005
    SoCal
    nice avatar.
    EVO III 16g'd wagon
    stock tranny goin strong
    .. already ready for a bigger turbo
    Quote Originally Posted by chanwahyaoh
    Sometimes after I go poo, I just blank out and mindlessly continue my upward wipe all the way up the small of my back and end up smearing brown all over myself. Just kidding. That sucks about your laundry though...
    Jan 2006
    Atlanta
    Thanks Believe it or not thats not photoshoped...
    Quote Originally Posted by le wagon
    nice avatar.
    Jul 2005
    SoCal
    haha wow.. people these days.
    EVO III 16g'd wagon
    Jan 2006
    Atlanta
    break in tips
    I hope it's ok to link to other sties... If its not let me know...
    I found this really good write up on good ways to break in your car and comparing the different opinoins...
    http://www.wrxfanatics.com/index.php?showtopic=5706
    ________________________________
    2005 WRX STI - Completely Stock
    Jan 2006
    Flipture,
    I didn't read the link that you gave at the bottom of your last post (I couldn't be bothered signing up with that site right now), but I do relate to your concern to raise a healthy engine.
    Until a year or two ago, I was fairly convinced in my own mind that the best way to break in an engine was to nurse it for the first 1500 km until the rings had bedded. I would cringe at the thought of people buying new cars and then driving them hard whenever the need/desire arose, without a care in the world for the poor, developing infant under the bonnet. And this view came largely from the influence of my Dad and the tendancy towards mechanical sympathy that we share.
    But a website on engine break-in completely changed my understanding of what happens inside new engines and therefore how they should be run in to maximise performance and longevity. This site is "www.mototuneusa.com/break_in_secrets.htm".
    According to the information on the site, cylinder walls are engineered with a cross-hatch pattern that is designed to assist the rings to bed to the wall. This patterned surface wears fairly quickly, however, and since it provides the only chance for the rings to bed properly, it is crucial that the rings create a good seal on the bore before the cross hatch is abraded. The window of opportunity here is in the first 35-50 km only.
    So what sort of driving makes for adequate bed-in? The sort that provides sufficient combustion chamber pressure to force the rings to flatten and expand outwards against the bore. That is, hard driving.
    Believe me, it took a fairly convincing argument to sway me from my old view. And a convincing argument is certainly given on the site mentioned above. Obviously, what I have mentioned here is just a brief summary of information given on the site, which provides a fairly detailed analysis of the process, along with information and photos of many engines that have been run-in using this method and ones that have not.
    Well worth a read!
    Jan 2006
    Atlanta
    good info! If anyone has actually tried these processes and has more than say 50k miles could you let us know how your car is running? 100k would be even better.
    I'd like to know the ups and downs of both ways of breakin and if there may be an in between. From what youre saying i'm getting that you should not simply rhomp on your car to break it in, be nice kinda like the dealer suggests but also give it a little hard drivin within the limits of the dealer recomendations...?
    Jan 2006
    Atlanta
    Break-in how to
    Since you actually have to sign up at the other web site to see this post i'm quoting it over here. I hope this is ok, it is from wrxfanatics.com and was posted by hotrod who seems to be a very knowledgable user...
    One of the subjects most likely to get a heated debate going on a car forum is a discussion about proper break in.
    There are generally two points of view:
    a. The engineers who designed it know best -- RTFM
    b. Drive it like you stole it
    Both points of view have their merits, but lets take a moment to look at what the break-in is for, and why the manufactures make specific recommendations.
    Before I discribe how I broke in my car, a few comments on how and why.
    A new engine (or any other mechanical device) is a little like a new pair of shoes. Everyone knows from experience what would happen if you put on a brand new pair of hiking boots and went for a long run. Big time blisters on your feet. In a mechanical device the same sort of high pressure injury occurs, but an engine or a gear does not blister, and cannot heal. You either break it in correctly or you damage it permanently.
    The Break in process is actually a carefully controlled form of wear, like the new shoes, it is a chance for the mating parts to "adjust to each other". In a shoe and your foot, most of the adjustment takes place as the shoe leather stretches and softens from repeated flexing. To a lesser extent your feet will form a callous to protect any area where a pressure point persists.
    No engine, bearing, gear or other mechanical device is perfect. If you look at a machined surface under magnification a piece of steel that looks to be smooth and polished is actually as rough as sand paper, only the peaks and valleys are on a very small level. When a machinist turns a shaft to a certain size, he is actually working to an acceptable error called tolerance. The crank shaft main journal may be specified to be 2.5 inches + or - 0.0002 inches and a surface roughness of maybe 50 millionths of an inch. A fine human hair is about 2 thousands of an inch in dia. So the acceptable error in diameter of the bearing is plus or minus 1/10 of the diameter of a human hair, and the acceptable roughness is about 1/40th of the diameter of a human hair.
    The bearing clearance is the space between the bearing journal and the bearing shell surface where the oil film is supposed to exist. Lets suppose the clearance on this crankshaft is supposed to be 5/10000 of an inch to 7/10000 of an inch. Now suppose you take a bearing that is on the small side with a nominal clearance of 5 ten thousandths and put it on a journal that is at the large limit of 2.5002 inches. You have an actual clearance between those two high points of only 3 ten thousandths of an inch. On another journal in the same engine you might have a large bearing that has a nominal clearance of 7 ten thousands of an inch and a small journal that is only 2.4998 inches in diameter. On this bearing the actual clearance would be 9 ten thousands of an inch. Needless to say the bearing that has a true running clearance of 3 ten thousandths of an inch is going to have much less room to expand if it gets hot than the looser bearing journal that is at 3x the clearance.
    In real life the crank shaft journal actually moves around inside the bearing. On average the bearing maintains a thin oil film between the moving parts but from time to time, under high loads or just due to random vibrations and variations in oil pressure and such, the bearing and journal will move into very close contact. Over time this will "burnish" the high spots down so the average surface is much smoother than it was when it came out of the factory. If you imagine the sandpaper like surface it had from the factory on a microscopic level, over time the appearance of the surface roughness will begin to look like a lot of table top mountains, as the upper most points on the the surface get either worn or beaten down by millions upon millions of small impacts.
    The break in process is intended to facilitate this "wearing in" process with out giving your engine the mechanical equivalent of a blister.
    [ what is a mechanical blister ?? on a fly wheel or a brake disk it is a premanent hard spot created by overheating a small high spot which is rapidly cooled by the metal surrounding it. This portion of the flywheel or brake disk will never wear at the same rate as the rest of the disk and will cause chatter and uneven friction for the life of the part. On a bearing it can be a hot spot on the surface that either hardens or softens the bearing surface or destroys the thin wear resistant coating put on by some manufactures. On a gear tooth it will be change in the hardness of the surface of the gear tooth that will make it wear or break under load. It could also lead to micro-cracking due to the rapid heating which will permanently weaken the gear. On a piston ring it can be scratching or scoring of the cylinder wall so the engine will always use oil to a softening of the piston rings due to over heating that results in poor ring seal and low compression and oil consumption.]
    How do you allow controlled wear? You have to create a situation where you have sufficient load to create the brief periods of close contact required, without over heating or damaging the bearing surfaces. The problem is that each mechanical component needs slightly different conditions to allow this to happen.
    The RTFM approach to auto break-in will give you a reliable car that does not require any warrantee work due to problems you created by mistreating the car in its first few miles of use. IT DOES NOT necessarily give you the best running car, or the most horsepower from your engine.
    The drive it like you stole it approach will MOST of the time, give you a powerful engine, but may lead to various trips to the dealer for things you pushed too hard too soon during the first few miles of driving.
    The best break in approach is about half way between these two extremes. The cam shaft and the cam followers are among the most heavily loaded parts on an engine, and need special care during the first hour or so of engine operation to avoid permanent damage. The bearings through out the engine and the gears in the transmission and differentials also need a pattern of alternating load and time to cool starting at low intensity and gradually increasing stress, to avoid permanent changes in gear hardness. The piston rings require brief periods of heavy load (hard acceleration), to seat the rings, followed by time to cool. The brake pads and brake disks as well as the flywheel and clutch need a progressive pattern of bedding in for the friction material and friction surface to get properly conditioned to avoid permanent damage due to over heating or poor performance due to improper bedding.
    Most people think of the break-in process as applying to the engine, but it actually applies to the entire car and all its systems.
    So what do I recommend for a break-in procedure?
    First, cater to the cam shaft and the bearings, piston rings and cylinder walls in the engine. Start the car and hold the engine at a slightly fast idle (about 1500 -2000 rpm), let the engine run at this fast idle with slight variations is speed for about 30 minutes or until the engine is at full operating temperature for a minimum of 10 minutes.
    Second, begin the bedding in process for the clutch, brakes, and the break-in process for the gears and piston rings/cylinder walls.
    Take the car for a short drive (drive it home). Make a point to not slip the clutch too much, or ride the brakes too much, accelerate briskly up to the recommended rpm limit the manufacture gives in the break in guidelines, but be sure to give plenty of time between the periods of brisk acceleration for the engine to cool any hot spots. After you have several minutes of driving on the car, in a safe location, make some moderately hard stops to begin the bedding process on the brakes, but space them well apart so you never smell hot brakes. By now you should have a feel for the clutch, make a couple moderately hard accelerations which load the clutch a bit, again with plenty of time to cool. By now you should be home. Park the car someplace where you will be able to see any drips, and let it cool completely.
    After the car has cooled down, check all your fluids to be sure all your levels are good. Look under the car and check for drips.
    Take the time to give the car a good visual inspection. Think like a pilot giving a plane a pre-flight. Grab stuff and try to shake it, check tire pressures, oil levels, get out the owners manual and learn where the transmission fill is, where the brake master cylinder is, where the fuse boxes are, how to turn on the 4 way flashers etc.
    Now your ready for phase 2. Take the car for another drive, where you have a lot of stop and go driving. Find a residential neighborhood that has lots of stop signs and learn the feel of the clutch. When conditions are safe, make a few brisk accelerations to seat the rings and bed in the clutch, then pull your speed down briskly (about 50% effort) with the brakes to help bed in the brake pads. Again be sure to give the car plenty of time to cool with easy "grandma driving" between these bursts. (be careful your brakes will not grab at full strength until the bedding process is complete - don't put your self in an emergency must stop situation !!)
    Jan 2006
    Atlanta
    Find a low traffic highway and make a max effort acceleration up the on ramp to highway speed, revving the engine to the max rpm listed in the manufactures guide lines in each gear (lets not go 140 mph here guys blink.gif just 1-4 th gear ). cruise for a mile or two, to let everything cool and then find a safe place to make a 75% effort stop or two. Do this several times then take it home and let the car cool over night. Follow this pattern for a couple days, gradually increasing the level of effort on brakes, clutch and acceleration until you have about 200-300 miles on the car. At this point you should be able to make max effort stops and accelerations, but still limit your engine rpm to the max rpm recommendation by the manufacture.
    From this point on, drive the car hard (safely!!) and every 100 miles or so, raise your engine rpm limit by 100-200 rpm. By this time you can make long highway trips with no problem, just avoid running on cruise control for extended periods of time. If you do use cruise control, periodically vary both speed setting and/or alternate between 4 th and 5th gear.
    Switch to a quality synthetic oil on your first oil change, and by the time your at about 3000 miles you should have finished all the break in that requires special precautions. The engine will continue to gain power for the first 5 - 10 thousand miles as it slowly loosens up.
    As an example of how these principles came about, here are some other examples of break in guide lines.
    As far as manufactures recommending it, they have, but only to that fraction of their customer base that are likely to understand it. Several manufactures have specifically recommended this sort of high load, with cool down to racers.
    The one I'm familiar with is Chrysler Corp when they introduced the Street hemi.
    For their racing buyers they told them to follow the following sequence to break in their race engines for drag racing.
    Start them up and let them idle at a fast idle 1500 rpm or so for 20 minutes or so. ( most cam shaft manufactures recommend the same for new cam shafts ) Then after checking for leaks etc. let the engine cool down completely.
    Next make runs at 1/4 throttle , 1/2 throttle, and 3/4 throttle, each followed by a full cool down. Make a final full throttle pass then go racing.
    Carrol Smith one of the most respected racing engineers in the business, goes to great length in his book "Tune to Win", and then bothers to repeat the same advice in a following book about how important this sort of periodic high load, followed by cool down is to proper break in of differential gear sets.
    Several major engine builders describe how they dyno break-in an engine and they also use the same pattern. 30 minutes or so of moderate fast idle to warm things up, followed by brief runs up through the engines rpm range under gradually increasing load, followed by cool down cycles.
    Mark Donohue the famous race driver describes how he broke-in race engines after rebuilding them in his book "Unfair Advantage". He liked to take the newly rebuilt engine and let it run at a fast idle for an hour or so, with a garden hose running in the cooling system to keep it cool. Then he would put it back in his car and take it to the track. By the time he finished his tuning laps and time trials for qualification, the engine was ready to race.
    Graham Bell author of the book "Four Stroke Performance Tuning" gives an example of a dyno run in process he uses on all his race and rally engines. To make it universal I converted the numbers to % of maximum torque.
    CODE
    rpm Torque min
    3500 25% 10
    4000 33% 30
    4500 45% 30
    5000 56% 30
    5500 66% 30
    Followed by cool down, adjust tappets, and retorque heads then full power runs for tuning purposes.
    Jan 2006
    Atlanta
    warming up your wrx
    does anyone let their car warm up to a certain point before driving it? And does anyone know if it helps and how much? I have been letting mine warm up to where the needle moves up to the bottom line. (when cold it sits below the bottom line) any suggestions / ideas?
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    I've been told that letting the car idle too long can actually be detrimental to long term use. I don't know that that's true, but I usually let mine idle for no more than 5 minutes before driving.
    As far as break-in, I just had a new engine built and I'm basically just driving it like normal. I've revved it over 4k a handful of times (when I need to merge on the highway and such). Otherwise I've been shifting it at normal rpms and haven't really been setting a self-imposed rev limit but not zipping around like a madman either. When I first pulled it out of the shop, we gave it a few nice almost full throttle pulls to get some heat to the rings. We'll see how the motor holds up...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
