Oil Drain Plug Size
Results 1 to 3 of 3
This is a discussion on Oil Drain Plug Size within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I did some searching around but I couldn't come up with a definite answer. I installed some gauges ...
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    Question Oil Drain Plug Size
    Hey guys I did some searching around but I couldn't come up with a definite answer. I installed some gauges and the last one to put in is the Oil Temperature. I need an adapter in order for the sensor to screw into the oil pan, but I'm not exactly sure what size the plug is. Can someone shed some light on this for me? Thanks!
    2005 CGM STi
    Registered User koji's Avatar
    Seattle, WA
    What kind of gauges, and what kind of sender are you looking at installing? Before you go try setting up a massive stack of brass adapters, have a look at http://www.wrxtra.com in their catalog.
    They sell pre-drilled drain plugs for the most common oil temp senders. Personally, I've got one of these but had to have it drilled out for a different size (thank you WorldOne).
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    what's the purpose of oil temp gauge anyways???
    It's not like it will warn you about anything
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
