Idle drop question
Results 1 to 8 of 8
This is a discussion on Idle drop question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi all, I searched for this but could not find anything. I recently noticed this (and I am not sure ...
    Aug 2004
    WA state
    Idle drop question
    Hi all,
    I searched for this but could not find anything. I recently noticed this (and I am not sure it the car did this all the time) when I come to a stop, put in the clutch the idle will sometimes drop just a wee little below 500 and then go to 500. Just curiouse if this is normal. The car is a 04 WRX wagon with a little over 13k on it. I recently changed the air filter (it is in right...PITA for me) and went to mobil synth. oil level is good. It runs great, just wondering if anyone experiences this also.
    Also, what does everyone get as a reading on the stock boost gauge at idle? Going to replace that soon with an omori in PSI Dang thing reads off zero when off pfft
    Thanks in advance and HAPPY NEW YEAR (and be carefull!)
    You might mean 700-750 not 550 or lower. If your tach is like mine it's easy to misread anything below 1K. Normal idle is ~750 and what you are describing is normal if you've misread the tach.
    Aug 2004
    WA state
    cool thanks!!! I will check again. it looks to be in the "middle" of 0 anf 1000. IT idles smooth though.
    Thanks again......I feel better now
    If it's in the "middle" then it's probably in the 700s since the tach starts at 500 or so. Normal. The car might shudder and rumble just a little at idle too, which is also normal.
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Yeah, for any car you want it to idle as low as it will idle smoothly. So if yours is smooth you're good. You only have an idle problem if it's low and rough or want to idle too high.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jul 2001
    Plains of Eastern Montana
    Having your car on defrost activates the ac compressor which will make your idle surge, then drop- only took me two years to figure that out
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    ^ THIS! You nailed it!
    Thank you!
    [My WRX '04, there was a surge & drop every few seconds in idle (cold or hot), sounded like pressing on the gas pedal, but the RPM stayed low, hardly moved at all. The oil gauge would bounce up then drop every few seconds, along with the sound of a fan activating somewhere. The defrost was indeed on.]
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
    Jul 2001
    internet is a great tool
