Stock boost pressure
Results 1 to 8 of 8
This is a discussion on Stock boost pressure within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi folks...n00b here... I just purchased a new '06 WRX last week, after a long list of Jeeps, trucks, and ...
    Dec 2005
    Ohio
    I just purchased a new '06 WRX last week, after a long list of Jeeps, trucks, and turbo diesel cars. My last "sporty" car was a 1992 Nissan Sentra SE-R, a far cry from the performance of the WRX. I've spent the last several years doing long distance motorcycle touring as well as some track time/Deal's Gap time on sport bikes, as I've always had the need for speed. I'm now getting back into performance cars after a long hiatus.
    After doing a little research I think a AP with a good exhaust will do the trick for me. I need to keep some level of reliability for my nearly 100 mile per day commute, and I'll need longevity - hopefully well over 100k miles without lots of repair. I'm no stranger to car work, having been a 20 + year experienced master tech (the last 8 years working for Mitsubishi before I quit wrenching), but I don't want to live under the car on the weekends. I only want to improve the performance because I think it could use a little more - which brings me to my question:
    What is the stock boost pressure supposed to be on a 2006 WRX 5 speed? My car runs ok, but I'm wondering if it is a little low on boost pressure...under full throttle & higher RPM I see .07 on the factory boost guage, which I believe translates into about 10 PSI of boost, right? Can anyone else with a stock '06 confirm whether or not that is normal boost pressure? Seems a little low to me. I did a search and found one post where someone said stock boost pressure should be around 13 PSI, but that was on a 2 liter engine.
    Help out a n00b, would ya?
    Bueller
    Dec 2005
    NorCal
    my friend just got an 06 and when we went to get a tune on it it came back as boosting at 14.5 psi, but with just a tune it is safe to put it up to 16.5 for everyday driving!
    hopes that hepled!
    Registered User brujito's Avatar
    Nov 2005
    Brisbane
    well since the 06 is a 2.5 it wont need as much boost as the 2l but yeah i still dont know what boost they are running just bought an 06 too and the salesman dont know either.... i need to get an aftermarket boost gauge to see i guess.....if you do find out can you please let us know....
    Oct 2005
    Las Vegas
    Stock boost on an 06 WRX is 14.5psi
    Dec 2005
    Ohio
    Thanks for the replies. I'm still curious to know what other '06 WRX owners are seeing on the factory boost guage under full throttle. If everyone else sees .07 on that guage I won't worry about it, but if others are seeing steady readings closer to 1.0 I might have a problem that needs to be addressed.
    Oct 2005
    Las Vegas
    Sorry the stock boost on an 06 is 13.5psi not 14.5
    Feb 2006
    Catty
    You should be seeing almost .09 mPa, on you stock gauge. If you dont hit that i would suggest trying a wastegate arm adjustment. That might help you out.
    May 2006
    Quote Originally Posted by WhiteReX2004
    Or take it back (you said it was an 06, right?) ... Either the boost gauge is defective, or you have a small problem.
