Compress Caliper with C-Clamp????
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
This is a discussion on Compress Caliper with C-Clamp???? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, I'm changing my pads today, and a friend told me it's bad for the ABS module to compress ...
    Registered User wrxaddicted's Avatar
    Mar 2005
    Southern Cali
    Hey guys,
    I'm changing my pads today, and a friend told me it's bad for the ABS module to compress the caliper with a C-clamp. Is this true? I have been doing this on my last 3 cars, and 2 of them had ABS. Please advise.
    thanks,
    Steve
    Administrator
    May 2003
    Quote Originally Posted by wrxaddicted
    Hey guys,
    thanks,
    Steve
    That's a new one for me. How does he feel you should retract the piston?
    Mar 2005
    Southern Cali
    blead em a little bit, push on the caliper as they bleed with something flat.
    Him and his dad own a tranny shop, so they know their stuff. On the other hand, you are a master machinic too, so i think I just will stick to my C-clamp ways.
    thanks for the prompt response.
    Administrator
    May 2003
    I'm sure it couldn't hurt, but I don't feel it's necessary. I've never had any adverse affects retracting the piston with a c-clamp/channel locks/pad spreader on ABS equipped cars.
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    I think they may be concerned that you would put one arm of the C-clamp on something such as a sensor. Just be careful to put one arm on the pad and one arm on the solid metal of the caliper and you should be fine.
    You could also ask your trusty Subaru dealership...
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    +1- just make sure you use the old pad as a block so you don't damage the piston
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    If you're bleeding the calipers at the same time you're not shoving any fluid back up the system anyway.....how do they suggest you do it? I found that I could push them back by hand quite easily with the bleed valve open.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Oct 2005
    long island
    It is supposedly bad for the system to compress with c-clamp. It can supposedly hurt valving in the abs system. this is what I was told in school. (I go to college for automotive engineering). I have never ever seen any adverse effects from compressing the calipers this way so I do it anyway. You are supposed to crack open a bleeder before compressing the piston with the clamp this way most of the pressure gets relieved through the bleeder and doesn't force it's way back through the system. I really don't think it makes a difference.
    Jun 2002
    Again, just how are you supposed to do it? I mean, the pistons have to go back one way or another. I don't see any difference between a clamp and by hand. I guess if the piston got hung up some how........but the ABS doesn't know the difference. If you don't open a bleeder all the ABS sees is fluid flowing upstream - cause unknown.
    Perhaps it's just a rule of thumb? If you can't do it by hand, something is wrong. The only way to really do it reasonably by hand if you're not King Kong is to open up a bleed valve. Then no fluid is flowing upstream and you can feel if the piston gets hung up (meaning you need a rebuild). Plus you get rid of any bubbles in the caliper......I guess that is a good way to do it. It's how I do it......
    1993 Honda CBR600F2
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    I just use the old pad. Point it skinny end toward the cylinder and push. Goes right in every time. Why mess with a c-clamp....just another tool to look around for.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Feb 2005
    south jersey
    Quote Originally Posted by YBNormal07
    You must be pretty strong
    Careful ya don't break a piston
    I don't open bleeders because then I have to actually bleed the system...
    Dirty Jersey
    RIP- '02 PSM Wagon
    Oct 2005
    long island
    The reason to open a bleeder would be so you don't force the brake fluid back to the master cylinder. Some ABS systems have check valves that will only let the fluid flow in one direction. If a bleeder is opened you would be able to compress the caliper by hand. If you don't open a bleeder it may be damn near impossible to do by hand. The correct way to compress the piston on a car with ABS is to open up the bleeder and then compress. I am unsure if you will see any detrimental effects to the system by not opening a bleeder. I have done it both ways and have never damaged anything.
    Jun 2002
    Quote Originally Posted by devilfluff
    Just put a piece of tubing on the nipple, start pushing on the piston, crack open the valve and out comes (usually) a little air and then fluid. Shut the valve when the piston gets all the way in. You've just bled the caliper and pushed the piston back.
    Why would you need to do more?
    1993 Honda CBR600F2
    Registered User ynotajb's Avatar
    Sep 2004
    mmmm,, tater salad
    Quote Originally Posted by GV27
    This is exactly what 06-wrx was saying to do ,,, and yes it does make sense and nothing more needs to be done,,,
    dude one time i tried to put the trailer bully into the coiler, and I got all messed up
    Feb 2005
    south jersey
    Thats an option, but you haven't actually bled the system... you've pushed the brake fluid behind the piston out the bleeder screw. If I crack a bleeder open, I'm doing a true bleed(pump, crack, close, repeat) to ensure there is no air in the entire system...
    And I've broken off enough bleeders to know that it ain't always that simple
    IMO its easier to put the inboard pad against the piston, center up a c-clamp, and push the piston home...
    Dirty Jersey
    RIP- '02 PSM Wagon
