oil level question
Results 1 to 5 of 5
This is a discussion on oil level question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; okay, so today when i went out to my car i decided to check the oil. i figured its been ...
    Jun 2005
    ct
    oil level question
    okay, so today when i went out to my car i decided to check the oil. i figured its been a while, it wont hurt. i checked it. the level was right at low. i checked it about 5 more times just to make sure and it was at low every time. this was all before i started up my car today. so figuring that i might as well add some oil i added 0.5 quarts of oil since i had it sitting in my garage. i check the level and it remains un chaned. so i start the car and move it foward about 5 feet to see if there is any oil n the ground. none. so i check the oil level again and it was even lower than before. so i drive to auto zone and pick up a quart of oil. the car was sitting for about 5 minutes while i was in the store. i check the level again before i add more oil and its above Full. i check it a few more times to make sure. and every time it was above full. is it bad for the engine to have a little too much oil in it? and why is it so wacky?
    Registered User wrxtuner2006's Avatar
    Oct 2005
    Pennsylvania
    Was the ground close to being level ?
    Registered User 04WhtWRX's Avatar
    May 2005
    Centreville, VA
    My Dad told me years ago that oil level is always lower when the car is cold. After you've had the engine running, it will show a higher oil level. I see the same with all the cars I've owned since, including my WRX. Also be sure you're sitting on ground that is as flat as possible.
    Jun 2005
    ct
    Quote Originally Posted by 04WhtWRX
    yeah its preety level. now anyone want to answer on if its bad for the engine to have a little too much oil?
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Quote Originally Posted by rbwrx
    Over filling the oil can be worse than underfilling it. But if its just a tiny bit, it won't be a big deal.
    Automakers try to limit the damage drivers can do to vehicles, so there is a little space between full and dangerous.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
