Churp Noise From Alarm Has Stopped
Results 1 to 15 of 22
This is a discussion on Churp Noise From Alarm Has Stopped within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This isn't a huge issue, but something I want to try and fix. I have a 2005 WRX Sedan, and ...
    Feb 2005
    Michigan
    This isn't a huge issue, but something I want to try and fix. I have a 2005 WRX Sedan, and the churp noise/ beep noise from when you hit the lock/unlock button, has stopped, and it doesn't make a noise anymore. The orange lights still flash when i hit lock or unlock and the button works fine, but it doesn't make the beep noise anymore. I tried disconnecting the battery for 5 minutes and hooking it back up, and it did reset everything, but the beep noise still doesn't work. Anyone else have these same problems?. Also, this might be a dumb question, but I just want to make sure, by un hooking the battery for 5 minutes my Cobb Basemap settings are still in there right, that wouldn't reset my ecu would it?
    Apr 2004
    Southeastern PA
    Have a look in the owner's manual. I think there is a button combination on the remote that turns it on or off.
    Mods & Pics
    Registered User wrxtuner2006's Avatar
    Oct 2005
    Pennsylvania
    There is. I tunred my chirp noise off because it got annoying .
    Feb 2005
    Michigan
    how do you turn it off and on?..i really don't feel like digging up the owners manual and searching through it?
    Oct 2005
    Pennsylvania
    It should say on the back of your black botton/ keyring thing. If yours is the same as mine then it is >press unlock once, then hold both the lock and unlock for two seconds. Thats it.
    Registered User le wagon's Avatar
    Jul 2005
    SoCal
    Mine doesn't chirp anymore.. at all
    I had it on chirp for awhile.. and it like wore out or something
    one day i pushed it and it went from a hi pitched chirp to low pitched.. to no chirp.
    not sure what happened, but i know i didnt change it to silent
    EVO III 16g'd wagon
    stock tranny goin strong
    .. already ready for a bigger turbo
    Quote Originally Posted by chanwahyaoh
    Sometimes after I go poo, I just blank out and mindlessly continue my upward wipe all the way up the small of my back and end up smearing brown all over myself. Just kidding. That sucks about your laundry though...
    Apr 2004
    Southeastern PA
    Quote Originally Posted by wrxtuner2006
    Well what do you know ... there it is plain as can be.
    Mods & Pics
    Jul 2005
    SoCal
    Quote Originally Posted by 04.SPT.WRX
    unless its dead like mine
    EVO III 16g'd wagon
    Registered User Houstonwrx's Avatar
    Jul 2005
    Houston,TX
    I have an 05 and have the same EXACT problem, it goes from chirping to not every now and then, even if I do the simultaneous button thing it still doesnt work. The button thing is just pushing both buttons down after unlocking it and that turns it off and on, I assume the alarm still works, I think it is a defect or something, I am sure I will take it in just because I can, but mine does the same thing.
    Registered User ynotajb's Avatar
    Sep 2004
    mmmm,, tater salad
    The beeper on my 04 works whenever it wants to ,,, It actually seems like it doesnt like to work in hotter weather,, Im not to worried about it though its not a big deal
    dude one time i tried to put the trailer bully into the coiler, and I got all messed up
    Feb 2005
    Michigan
    hahaha....wow you guys hit it right on. It works good in warm weather, and its now 45 degree's here....maybe 55 for the high...and it doesn't work that great....
    Registered User DJSHADOW7's Avatar
    Aug 2005
    AZ
    Even though my "beep" is off, once in awhile there it is again annoying as can be...
    Another thing i noticed, when both me and my friend (who also has a rex) hit our remotes at the same time the signals must interfere because only one of ours works, or neither work.
    The 05 key fob sucks, i set off panic all the time on accident.
    ...If you ever need anything please don't hesitate to ask someone else first.
    Blobeye Syndicate numero uno.
    Registered User Blofe's Avatar
    Sep 2005
    Long Beach
    Hey I acutually tried reasearching this issue, it's not something huge like the original post said, but f0ck it's mind bogglin' because i turned it off also cause it got annoying, then when I tried to use it again it like died or something so it kinda only worked for like a couple of months on my STi.
    So Cal F4 # 10
    Registered User scooter4483's Avatar
    Mar 2005
    norridge
    had the same problem 3 months after getting my car. then it completely stopped chirping. the dealership had to replace the chirping mechanism in the car. thats what you guys will have done if you want to get it repaired.
    chris
    Sep 2005
    Long Beach
    Did it cost you anything?
    So Cal F4 # 10
