Engine Codes
Results 1 to 5 of 5
This is a discussion on Engine Codes within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello all, I have a check engine light on my '02 WRX and am going to take it to advance ...
    Oct 2005
    Hampton, VA
    Engine Codes
    Hello all,
    I have a check engine light on my '02 WRX and am going to take it to advance today to get the diagnostics run on it so I can get the codes for the light. Does anyone know where I can find what all the codes mean?
    Administrator
    May 2003
    Quote Originally Posted by bkhweik
    Hello all,
    Post them when you get them, we'll help.
    Oct 2005
    Hampton, VA
    code was p0171 I guess I'm running too lean, I just installed a MBC last week, could my boost be too high?
    Oct 2005
    Hampton, VA
    I don't have a catless up pipe, my whole exhaust is stock (that's my next project), I have an MBC that's adjustable from the cabin, it's a bleeder valve type MBC... at first I was running about 15 pounds of boost spiking around 18 then I turned it down after I got my check engine light, I'm running 13 pounds spiking around 15-16.... when it spikes it's only for a split second then it'll settle to 13.... or 15 when I had it turned up
    Oct 2005
    Hampton, VA
    I appreciate the advice Trainrex, but could you elaborate on not running an MBC while I still have an up pipe cat... should I got an aftermarket up pipe cat? I don't quite understand what you mean. I don't know too much about cars so I need things in Lehman's terms explained to me I ask my friends for advice when I need it and I don't know if it's always the right kind of advice. Thanks!
