stock battery die in less than a year
Results 1 to 9 of 9
This is a discussion on stock battery die in less than a year within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; it's been sitting for two days and this morning, i can't start the engine. my passport reads the voltage is ...
    Nov 2004
    Seattle
    it's been sitting for two days and this morning, i can't start the engine. my passport reads the voltage is 12.5 - 12.7. i suppose that's kind of low to start right?
    now, the problem is, how can it get so low? when i'm driving, the voltage is usually 14.7 to 15. and this is a new car new battery.
    any comments?
    ray
    2005 WRX Wagon Crystal Gray Metallic
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    do you take frequent short trips, i'd say about 5miles??
    if you do than the battery doesn't have chance to recharge properly and will fail sooner than it supposed to.
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
    Jul 2004
    elk grove ca
    its your driving style and short trips, i have over 60k on the stock battery here and i make short trips alot but i usually let the car sit for a few hours or more to recharge.. either that or u got a dud for a battery
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Nov 2004
    Seattle
    i think it's not a battery problem. the voltage reads 12.8v so it's almost a fully charged battery. i called the roadside assistant and they are coming for a jump start. we'll see...
    ray
    Jul 2004
    elk grove ca
    Quote Originally Posted by WRayX
    ray
    well could be your alternator then, have you noticed your headlights and or interior lights getting low?
    14.160@96.011
    90 degree weather
    Registered User ScoobVee's Avatar
    Mar 2004
    Thats the normal range for a good battery w/ the car off, after its started it should be in the 13.9 - 14.7 range
    Edit : your battery isnt the problem
    - Local Riceist
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Quote Originally Posted by blackrex02
    You let your car idle in the driveway for a few hours or more to recharge the battery? If not, then your battery isn't recharging. That's the only option aside from a magically recharging battery.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Nov 2004
    Seattle
    the kid came and started my car with his portable jumper. but i still don't think it's a battery problem. why? with his portable battery on, i tried 3 times and each time letting the starter to work for 3 seconds. that didn't work, so he took the key and try. but he just let the starter run and run for like 10 seconds striage. then the engine started.
    i drove for half n hour and now when the engine stopped, it reads 13.2v. while i was driving, it reads 14.6v.
    i'll take the car in for a checkup tomorrow since the first warrenty is going in a month.
    ray
    Registered User 4cyturbowrx's Avatar
    Nov 2003
    philly
    Ray
    I have an 03 and replaced my battery in the first year, i replaced it with a higher amp battery. I dont have any other sorta electrical equipment in my car. I think its just subaru batteries. I use to get alot of dual and flickering lights when my car was at idle. The new battery solved everything.
