cruise control thingy
Results 1 to 7 of 7
This is a discussion on cruise control thingy within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; wondering if this is a common problem: the cruise control knob/slider/whatever vibrates like a banshee and is drive me nuts. ...
    Registered User lordcon's Avatar
    Sep 2005
    Abingdon MD
    the cruise control knob/slider/whatever vibrates like a banshee and is drive me nuts. its getting the vibration from the steering wheel i assume, and has this high pitched buzzing noise when you go over bumps or uneven pavement. i know it is definately the cruise control thing cause if i hold it, the noise stops.
    anybody else have this issue?
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    I had that problem for a while, so I finally took the assembly apart to see if I could put some sort of padding in there to keep the cruise control main button to stop rattling. I didn't have anything to do the padding at the time, I just wanted to see what the inside looks like. When I put everything back together, it didn't rattle. That was easily 6 months or more ago. Hasn't rattled since...
    I believe you need a small screwdriver set to get the cruise switch assembly apart. It only took a couple of minutes. Do a search. That's where I found a small writeup that someone did on this topic back then. Good luck!
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Registered User WRXNavigation's Avatar
    Aug 2005
    Central NY
    If you search you can find a TSB on the cruise control switch rattle. My 05 WRX had the cruise control rattle and the rear differential howl. So I printed out both TSB's for those problems and had the dealer fix them both for free. The cruise switch just takes a small piece of tape. The circuit board inside is what is rattling around.
    Sep 2005
    Abingdon MD
    cool, thanks guys.
    Sep 2004
    Indy, IN
    Quote Originally Posted by WRXNavigation
    What did the dealer do for the rear diff howl? I notice a bit of a humming noise when I have the car loaded (with someone in the backseat or heavier cargo in the back) while going over dips, bumps, or sharpish turns at highway speeds. Could that be related? I'd like to get mine in soon if it's a warranty thing because I'm already at 27,500 miles.
    Thanks,
    D
    Aug 2005
    Central NY
    I am not positive is the noises you are describing are directly related but it is possible. Mine was a distinctive howl around 60-65 mph. When the windows were up and you let off the gas at that speed it resonated in the cabin and was annoying to say the least.
    To fix the problem they replaced the upper differential support member and added to it two harmonic dampers. The harmonic dampers are the key. They bolted to the arms of the support member, one on each side adn were basically metal cases filled with hard rubber. They bolted down to the support member and absorbed the vibrations that were causing the howl. It reduced the noise by 90% for me. If you listen carefully you can still hear it but it is no where near what it originally was.
    It is a TSB so technically it does not matter if you are under warranty or not. But it will be easier to convice them that is what it is if you are under warranty. My service tech claimed he didn't hear the noise, I told him I don't care if he heard it because I hear it every day and I want the harmonic dampers added anyway.
    http://www.scoobymods.com/forums/showthread.php?t=5275
    Good luck!
    Nov 2005
    Bay Area, CA
    AWESOME!!!!!!!!!!!!!!!!!
    I searched thru 10 pages for "cruise" and finally found my rattle issue!! So stoked.. Gonna try and fix it soon.. My rattle also goes away when i keep my hand on the cruise control stalk..
    B-IZZZ-ONUS
    2015 Subaru WRX Limited
    2015 Subaru Forester XT Touring
    LastHumansGarage
