Check engine light....
Results 1 to 11 of 11
This is a discussion on Check engine light.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; was wondering if anyone knew what is wrong with my car...the check engine light shows that its my mass air ...
    Sheboygan, WI
    was wondering if anyone knew what is wrong with my car...the check engine light shows that its my mass air flow sensor....so i bought a new one reset my ecu...it its still on....anyone know what might be wrong or knnow how i can fix this problem...maybe i should mention to that i just had my car flashed with ecutek....the power is there but the check is on...and i the guy that tuned it told me to get a new sensor too....and so i did...and still, problem not fixed...help...
    Administrator
    May 2003
    Are you running any type of intake?
    Sheboygan, WI
    yea...the Injen short ram
    Administrator
    May 2003
    Quote Originally Posted by MyWRX
    I'm not saying this because I'm an intake hater. I myself have a K&N Typhoon short ram. If you have your stocker, try putting it on. Some intakes tend to skew the MAF signal.
    Sheboygan, WI
    i thought it wouldnt fit because i have my fmic pipings in the way....true or false that i cant fit it...
    Administrator
    May 2003
    Ah hah! Please ignore my previous advice. Didn't know you had a FMIC.
    Sheboygan, WI
    anyone have any idea...
    Administrator
    May 2003
    Check that the air cleaner isn't clogged, or leaking air from it's connection. Check the MAF plug for water, or bent pins. Also check that the wires aren't pinched anywhere. Aside from that, since you already replaced it with a new one, I would say it's a tuner issue.
    Sheboygan, WI
    yea,...the guy said it has low voltage or something.....im not sure what he meant from that...maybe someting might be lose but i already checked it over....
    Sheboygan, WI
    bump...
    still cant figure it out...help..
    Registered User scotts05's Avatar
    Sep 2005
    Beavercreek, OH
    Tighten your gas cap? Loose gas cap may turn the check engine light. It says so on the gas cap.
    2005 Ubaru Impreza WRX Sedan Crystal Grey Metallic
    Mods: In my profile
    http://www.myspace.com/scottycruz
