Skid Plate Removal During Oil Change
Results 1 to 7 of 7
This is a discussion on Skid Plate Removal During Oil Change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I decided to try one of those fast lube places on my way to work (I haven't had a ...
    Jun 2004
    NY, NY
    So I decided to try one of those fast lube places on my way to work (I haven't had a chance to go to my normal mechanic) and they charged me a $3.99 "Skid Plate Removal" fee. When I questioned them, they said most new cars require the skid plate to be removed in order to change the oil. I have a stock 2004 WRX wagon. Is this legit? They seem to try to get you with the cheap base price but get you with these add-ons (like +$6 for the Mobil 1 oil filter).
    Thanks,
    Rich
    Jul 2005
    Quote Originally Posted by RichE
    Thanks,
    Rich
    I think I've heard of some people doing the change without removing it, though most who do like to modify the plate and cut a bit of a hole.
    All-in-all I'd say that yes you have to remove it, but that doesn't mean the fee makes much sense. It can't take more than 5 minutes to take that thing off, and it probably takes less.
    I've yet to change my oil (only at 2K) so this is all from what I'd heard.
    Even if you did modify the plate (it's really plastic AFAIK, plate seems to elicit thoughts of metal) they'd probably still charge it. Plus, the plate is there for a reason and it's probably not in your best interesting to modify it.
    Cliff notes: Yes, you have to remove the plate to change the oil, but $4 is kind of a rip off. That's their way of still offering $19.99 oil changes but staying ahead of inflation and making more money.
    Registered User kram941's Avatar
    Jul 2005
    wilmington, MA
    Probly not much help but on my 05 sedan I didnt need to remove the skid plate.
  5. #4
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    I have an 04 as well. It's 4 pop-clips and 5 bolts to remove the plate. I have entertained the thought of cutting access holes for oil changes but I've never done it.
    If I remember properly from the last time I changed the oil, its possible to change the filter without removing the unmodified plate, but not drain the oil. The oil pan would drain onto the plastic and go everywhere.
    DIY = no hidden fees!
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
  6. #5
    Registered User trippy's Avatar
    May 2005
    I don't see a problem of cutting a hole for the oil filter and drain hole. I've seen many aftermaket skid plates with these holes including the one from SSI.
  7. #6
    Apr 2004
    Southeastern PA
    Thanks,
    Rich
    Learn how to do it yourself. With a few simple tools and a drain pan it is easy. Then you will know it is done correctly.
    Yes, charging $4 for that is lame. It too is easy to remove.
  8. #7
    Jul 2003
    NNJ
    Quote Originally Posted by 04.SPT.WRX
    +1
    Pick up a Fumoto valve and then (providing you cut the holes in the skid plate) you can change your oil with NO TOOLS.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
