fuel question
Results 1 to 11 of 11
This is a discussion on fuel question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i am looking into getting a new 2005 wrx and i was wondering if the car requires octane 93 fuel? ...
    Aug 2005
    Old Bridge, NJ
    fuel question
    i am looking into getting a new 2005 wrx and i was wondering if the car requires octane 93 fuel? would it be ok if i were to put regular or maybe even the middle one octane 89?, would it hurt the engine if i didn't put octane 93 all the time?
    thanks
    Registered User cyrilgrey's Avatar
    Nov 2002
    Queens, NY
    This car requires a minimum of 91 octane to perform as advertised, otherwise known as "premium" fuel.
    If you fill the car with 87 the computer will sense a change in the way the engine runs and will make alterations resulting in a large loss of power. The car will run, no damage will occur, it will not perform the way it was intended to.
    If you are worried about the expense of premium fuel do not buy a WRX or a similar performance car.
    Mid range octane fuel is a marketing gimmick to make money off uninformed consumers. I cannot think of a single car rated for 89 octane. Either 87 or 91/93 are recommended. Unless you are experiencing slight pinging in a built motorcycle engine, or a car intended for 87 suffering the same, 89 is a waste of money.
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    any FI car will require 91+ octane. for example, when i moved to california with my old after market turbod car, i had to turn my boost down to 6.5psi because they only have 91 octane around here.
    the sti requires 93 (the manual says i believe).
    Jul 2005
    Quote Originally Posted by cyrilgrey
    Technically damage can occur. In order for the ECU to react to pinging, pinging must first occur. That and once you put regular in you'd probably need to reset the ECU to advance the timing all the way back to 16.
    Quote Originally Posted by lilneel12
    thanks
    It is a HORRIBLE, HORRIBLE, HORRIBLE idea, not to mention a COMPLETE waste of money, to put anything other than 93 into a WRX. Someone on NASIOC (and this is not verified) said they saw someone ran a dyno and saw a 40 WHP loss when going from 93 to 87.
    The difference between 87 and 93 has remained a fairly constant 20-25 cents per gallon for the last forever and a half. At 12 gallons per fill, that is (on the high side) 3 dollars per fill. At even 8 fills per month, or 2 per week (24 gallons @ 20 mpg = 480 miles per week = 25,000 miles a year), that's $24 per month. At 12 months, that's $288 a year. If your financial well-being is dependant upon a $288 yearly dynamic, you've got bigger issues.
    Note the above used worst case scenario variables.
    Putting 87 even in one time (emergency) is bad. That'll set the ECU back quite a bit in the firing sequence.
    If you put it in for 500 miles, you may as well buy a 2.5i or RS.
    May 2005
    some of us cant get 93.
    Registered User drummerboy's Avatar
    Aug 2005
    putting 91 octane isn't bad. the spec for wrx is 91 anyway. i think only sunoco offers anything greater that 91 (94)... but they're not at every corner over here.. but i do agree that 87 is definitely not a good thing.
    2006 WRX - World Rally Blue
    Jul 2005
    Quote Originally Posted by 05WRX0704
    I pretty much meant 91/93.
    BP, Sonoco and Shell offer 93/94.
    Nov 2002
    Queens, NY
    Some ping events will not impact the engine overall. The ECU is designed to adapt before damage actually occurs. It takes a while to cause any.
    Jul 2005
    Learn something new every day.
    Either way, WRX - 40 HP = might as well get a 2.5 RS or 2.5i.
    Aug 2005
    Old Bridge, NJ
    wow, i didn't realize it would gas would effect it that much, thanks for all of the info guys
    Jul 2005
    We're here to help and harass.
