opinions/advice. gear oil question
Results 1 to 5 of 5
This is a discussion on opinions/advice. gear oil question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have 5 quarts of redline D4 ATF synthetic (rated at gl-4) left over from my 4eat 04 wrx. When ...
    Registered User BrandonWRX's Avatar
    Feb 2003
    Sharon, PA
    I have 5 quarts of redline D4 ATF synthetic (rated at gl-4) left over from my 4eat 04 wrx. When checking my sti tranny fluid level, it is halfway between L and H. Im thinking this might be the cause of some subtle grinding here and there and some 1-2 shift problems at redline. For example when im at the strip, the 1-2 shift takes wayyy too long and it is as if I hit a barrier between the 1-2 shift before the synchros work and it goes in, still with some difficulty. When the car is cold I have to double clutch just to downshift into 2nd at a low speed. This is in 90 degree weather, god knows how itll be once it starts getting cold.
    So my question is, could I add some gl4 redline synthetic atf to the stock oil to fill it up? Other gl4 rated tranny fluids such as redline shockproof and gm synchromesh are used in the tranny without problems. I would only add 0.5 qts at the most. What do you think?
    PS-I know hypoid gears in the front diff require gl5, just trying to get the synchros to work better.
    MY MODS
    *GET YOUR CLUBWRX KEYRING*
    http://clubwrx.net/forums/showthread.php?s=&threadid=54791&highlight=keychai n
    Feb 2003
    Sharon, PA
    noone?
    MY MODS
    Registered User cyrilgrey's Avatar
    Nov 2002
    Queens, NY
    No. I would definitely not. As mentioned in the the other thread, try throwing some lucas gear oil in the transmission. See if that helps with the synchros.
    Feb 2003
    Sharon, PA
    yeah this thread predates the other one by a coupel days. I decided on dino 75W90 but came across lucas and bought a qt. I'll post any changes in the other thread.
    MY MODS
    Nov 2002
    Queens, NY
    lucas = good stuff
