HELP!!!! dtc codes
Results 1 to 6 of 6
This is a discussion on HELP!!!! dtc codes within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 2005 wrx and the cel is flashing so i hooked up a scan tool to it and ...
    Dec 2004
    HELP!!!! dtc codes
    i have a 2005 wrx and the cel is flashing so i hooked up a scan tool to it and saw that most of the codes had to do with low voltage or low input. it threw a P1518, P0851, P0137, P0502, AND A P0503. any suggestions on how to fix this? i have a full exhaust, intake and boost controller.
    Registered User Treefrogaz's Avatar
    Apr 2004
    Luke AFB, AZ
    Quote Originally Posted by BPL294
    I really dont know what to tell you but the codes that you threw are......
    P1518 Starter switch circuit low input
    P0851 Neutral suitch input circuit low
    P0137 O2 Sensor circuit low voltage bank 1 sensor 2
    P0502 Vehicle speed sensor low speed
    P0503 Vehicle speed sensor high speed
    Hope that helps some good luck to ya.
    Dec 2004
    any one have any idea what would cause the low input codes???? the battery is fine the connectors are fine... the car was diconnected from the battery for about a month or so, dunno if that means anything...
    Registered User SicWRX37's Avatar
    Charlotte, NC
    Did these codes apear after installing your aftermarket parts?
    P0137 O2 Sensor circuit low voltage bank 1 sensor 2...That code means your sensor is reading lean most likely because of your intake(same thing happened to me).Your PCM is compensating for your lean condition but you will probably notice crappy gas mileage, and a check engine light that will always be on.
    These two codes are probably from a bent, chipped, or missing tooth from your VSS wheel. So its giving false readings at all speeds. Pull of your wheels one at a time and inspect each toothed wheel.
    those two are probably like you said from the battery being disconnected for so long.
    I hope that helped in someway.
    Let us know what you come up with.
    Dec 2004
    these codes came up after i got in an accident. before the accident i had all the aftermarket parts in there and i had a solid cel im guessing from the exhaust. but i just got it back and its blinking. in the accident i messed up my driver side back wheel pretty bad so that vss code makes sense now. ill check out the teeth on the gear on that tire.... thanks alot
    Charlotte, NC
    that solid cell you had i can almost gaurantee is from that intake. If you can get a hold of a scanner that can show live data do it....if you do get one look for HO2S11, thats your bank 1 sensor, if its reading below .45 volts your running lean that being the meaning of O2 Sensor circuit low voltage. Let me know what you come up with im interested in what you find.
