how to close gap on ngk iridiums
Results 1 to 7 of 7
This is a discussion on how to close gap on ngk iridiums within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm planning to buy some 1 step colder ngk iridiums and I found out that the gap is somewhere around ...
    Registered User prspect06's Avatar
    Feb 2003
    Land of the Kings
    I'm planning to buy some 1 step colder ngk iridiums and I found out that the gap is somewhere around .40. I read that the optimal gap should be between .28 and .30 so I need some closing up to do. I also read that the iridium tip is very fragile. So how should I go about closing the gap on the plugs?
    Feb 2003
    Land of the Kings
    bump...need some advice please
    Feb 2004
    i wouldn't buy the iridium, i think the copper works the best.
    Feb 2003
    Land of the Kings
    well...i already purchased iridiums and i need help with those.
    Registered User cyrilgrey's Avatar
    Nov 2002
    Queens, NY
    I have these plugs. The tip itself is fragile, so don't hit it. The strap, however, is the same metal as always.. so I pushed it against a concrete wall until it bent to about where i wanted it, checked the gap, readjusted with wall if necessary, and installed.
    Jun 2005
    South Dakota
    You really don't want to narrow the gap. A wider gap will burn the fuel more efficiently. I can't remember the exact science at this moment, but the wider the gap the better as long as your coils can fire it. I always ran a .50-.55 gap in my cars but I always upgraded to a Accel Supercoil. I don't know much about the coils on a WRX, though, so I might just be blowing smoke where they are concerned.
    Nov 2002
    Queens, NY
    I would stick with the manufacturers recommendation.
