Craptastic Gas Mileage - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
This is a discussion on Craptastic Gas Mileage within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; lucky bastard...
  1. #31
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    lucky bastard
  3. #32
    Jul 2004
    elk grove ca
    Quote Originally Posted by 05WRX0704
    lucky bastard
    i wouldnt called lucky necisarily.. as far as i know thats how the ej20 is engineered.. i noticed very very negligible differences when driving conservative and driving aggressive.. sometimes the numbers were backwards,,,,the only time i got great gas milage was when i shifted at 2800 rpm and never hit boost by listening for it.. i got 26mpg...i got 26.2 by driving up to the mountains and coasting back down... that was with alotta spirited driving mixed in too
  4. #33
    Registered User IHRTWRX's Avatar
    Mar 2005
    NOR CAL
    Quote Originally Posted by blackrex02
    no im just pointing out that beyond all that i still got almost 22 mpg
    Ahh. I see. Yeah mine doesnt seem to change much unless one tank is very spirited and the next pretty much deprived of boost.
  6. #34
    Registered User perfusionista's Avatar
    May 2004
    Boulder County, CO
    I make a 285 mile trip almost every weekend, interstate almost door-to-door, but hilly in parts. I get it up to 90 and put the cruise on. I usually just make it as the light comes on. That's 13 gallons, 22mpg. A strong head wind will drop it 2mpg! If I up the cruising speed to >100, then the mileage is about 18mpg. I'm intrigued by these people who get 26 or 28, how fast (or should that be slow?) do they drive? I've been tempted to find out what the mileage would be at a 55 cruise, but the boredom (and spending an extra hour-and-a-half on the journey) would kill me. I gave up on the tire pressure idea. I used to run 36/34 and all it did was give me too much wear in the center of the tread.
    I think you answered the question yourself: "wow. about 500lbs heavier than my old car"
  7. #35
    Registered User 05silverWRX's Avatar
    Feb 2005
    Nashville, TN
    Crusing at 75mph I will get 28 mpg, but that is cruising at 75mpg the whole tank (350 - 375ish miles)
    2013 WRX SWP
  8. #36
    Registered User boosted scoob's Avatar
    Aug 2004
    Robins AFB, GA
    350 mi on 14.2 gal interstate driving @ 70mph. My car weighed in at 3250 at the track.
    02 WRX - XS Power header/UP/TBE, XS Power FMIC, MBC@15psi, Ported TD04L, Perrin shortram, Alum Radiator - 13.35@101
    05 Mini Cooper S - Bone stock
    95 Mustang GT conv. (Work In Progress) - BBK LT headers & h-pipe, dumped Flowmasters, Kirban AFPR, BBK subframe braces, 6-point rollcage, FMS springs, 70/30 struts, 50/50 shocks, K&N intake
  9. #37
    Jul 2004
    elk grove ca
    Quote Originally Posted by perfusionista
    light turns on when theres 2.3 gallons in your tank... 15.9-2.3= 13.6 gallons
  10. #38
    May 2005
    thats a good bit left
  11. #39
    Registered User AKESREX's Avatar
    Oct 2004
    So. California
    mileage
    On my 2002, at 74000 miles, I've noticed very slight degradation on fuel mileage.
    At a cruise control setting of 70mph in the middle of nowhere (Utah, Nevada, etc)
    it'll get a little over 29. The best it got brand new under similar conditions was 29.8
    mpg. Under normal highway driving conditions mine does no better than about 27
    on the best day. Mixed city and highway seems to yield me around 23-25 mpg.
    Pure city driving, putting around with low or no boost involved, will net you 21-22
    or so. All the above is on crappy CA gas. And there is a significant variance in
    CA gas, tankful to tankful. Some of it is truly lousy. I've got some 91 Shell in the
    tank right now that is posting some of the largest numbers on the boost gauge
    that I've seen in the past three years.
    My car has no mods. And yes, in stock form the WRX is very fat in terms of fuel
    trim as a warranty safeguard.
  12. #40
    May 2005
    Im lucky to get 170 miles to a full tank of gas. I drive to school and work everyday.. Abut 30 miles a day
  13. #41
    Apr 2004
    Southeastern PA
    Quote Originally Posted by devilfluff
    I get 22-23 mpg.. about 320 miles per fill up-- no matter how I drive usually- But I do mostly highway, which helps
    I get about the same - 21 to 23. It's mixed suburban / rural driving with some highway. And that is with stage 2. (I <3 the wiggler!) >>
  14. #42
    Registered User Bucket's Avatar
    Jun 2005
    PA
    Hi All. New to this forum. Just bought an 04 wagon last month. I've been tracking fuel mileage since. I keep a note pad in the console and write miles and gallons every fill-up. Then, when I have gone through a few tanks, I transfer it to Excel.
    I highly recommend this method to everyone. Your MPG for one tank is not a good indication of what is going on with your car. The pump where you got gas might shut off half a gallon earlier than another. The concrete at the gas station might be sloped one way or another... What I'm getting to is that there are variations in how full the tank gets each and every fill. If you keep track of the mileage every fill-up, then you will know what your average MPG is. Right now, mine is about 25.4mpg averaged over 4 tanks. I missed one tank when I let my Dad drive the car to work, he filled it up without keeping the log. Would have been all highway miles too, bumping up the average a little probably.
    Anyway, my high mileage is 30mpg. My low is 22mpg. The former is all highway, mostly under 80mph. The latter is mixed city/hwy seeing what the car can do.
    Please try it. You'll like it..
    Buck
  15. #43
    Registered User god910's Avatar
    Mar 2005
    Muncie, IN
    Taint no poo my friend. I was filling up at a certain station, and was wondering why my light was coming on w/ 5 gallons in the tank. Well, it wasn't. I discovered this when I switched stations and got 15 mpg. Went back to old station and got 27, w/ city driving. I figured out it was just the different filling. I keep ALL my rec. in the car and write the mileage on all of them. Avg. it out every week (Every 5 days to be exact) I get 20-21 mpg. And am MORE than happy w/ it. 92 Olds Gutlass, 3.1V6, no HP, decent torque, 20 MPG, FWD. SO, AWD, MUCH faster, I'll take it!!!!!
    (Of course, my decently quick 87 Daytona got/gets 30+ mpg and low 14's)
    Sonic Yellow Snow Cone
    My Mods
    "Is that your dog sled?" "I'm standing next to it."
    Quote from TFATF-4 Anchorage Drift
