Coolant temp sensor location??
Results 1 to 10 of 10
This is a discussion on Coolant temp sensor location?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Need a little help here guys... I've been searching all over the net for the answer to this. Legacy forums ...
    Nov 2003
    Chicago, IL
    I've been searching all over the net for the answer to this. Legacy forums are pretty much nonexsistant. I'm working on a friend's 95 Subaru Legacy and it had a CEL. Pulled the code and it's supposedly the coolant temp sensor. I've been nosing around the engine bay and I can't figure out where the heck the thing would be. I don't want to buy a service manual for this car since I'm only working on it once and I figure that the 2.2L boxer motor in this car is similar to the 2.0L in the WRX....anybody know where the heck this coolant temp sensor might be located???
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    well on my protege it was inside the hose at the engine block. remove from engine block and you would find the sensor there...
    May 2005
    here it is, i believe, and if im correct it might help
    Registered User ScoobVee's Avatar
    Mar 2004
    Quote Originally Posted by 05WRX0704
    Geeze, if we had a rep points system here, you'd be pretty much in the hole right about now
    - Local Riceist
    Nov 2003
    Chicago, IL
    That's a thermostat...temp sensor is different (screws in a has a black harness I believe)...thanks for the effort though
    03 350Z - intake, test pipes
    Best STOCK E.T. 13.68@102.77mph 2.09 60'
    Best mods E.T. 13.38@103.60mph 1.90 60'
    May 2005
    dammit thats what i was thinking about, sorry
    May 2005
    does this help
    May 2005
    or this?
    May 2005
    last one
    Nov 2003
    Chicago, IL
    yes...thank you...I had a feeling it would be under the intake manifold....dammit. I've got some work to do.
