Stock tires question
Results 1 to 11 of 11
This is a discussion on Stock tires question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; are the stock Bridgestone Potenza RE 92 tires directional? If not why does the manual say to only rotate front ...
    Registered User RedlineWRX04's Avatar
    Mar 2005
    Cali
    are the stock Bridgestone Potenza RE 92 tires directional? If not why does the manual say to only rotate front to back? Just a noob question
    --04 Java Black Pearl--
    Injen RD 1200 Intake...soon to be gone.im not sure yet...
    Apr 2004
    Southeastern PA
    Nope. Tires that are directional will have an arrow on the sidewall indicating direction of rotation.
    Registered User zoinks's Avatar
    Dec 2003
    Portland, OR
    It's not a good idea to switch the rotation of any radial tire. Some tires are just meant to go in a certain direction from the start. Others you can start in either direction, just keep them in that direction.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by zoinks
    As in once they "get used to" spinning in one direction, keep them spinning that way? Yes, I would agree with that.
    Dec 2003
    Portland, OR
    Yeah on any radial tire, once it's been driven in one direction you don't want to change the direction. Also, some tires come stamped with an arrow from the factory as to which way the tire should rotate.
    Apr 2004
    Southeastern PA
    Me thinks me said that.
    Redline: You would be best off wearing out the RE92s as fast as you can. You can then replace them with some good tires and see what the WRX can do with proper shoes.
    Dec 2003
    Portland, OR
    Quote Originally Posted by 04.SPT.WRX
    Hmm wierd, I did too.
    I second that!! The stock tires HARDLY do justice. After putting on some BFG KDWS tires my WRX turned into a new car! New tires have got to be the cheapest most effective upgrade anyone can do to a WRX.
    Registered User subaru_crazy's Avatar
    May 2004
    NYC
    correct on the stockers you could not trust the car in turns but with some nice rubber like pirelli the car sticks through corners like glue on paper.
    MY LUG NUTS NEED MORE TORQUE THAN YOUR HONDA MAKES!!!!
    Cobb Stg 2 helix up/dp combo
    Kartboy short shifter
    Mar 2002
    Calmer than you are
    changing direction on some tires (MOST newer tires actually) increases the chances of tread seperation.
    go f*** yourself
    Mar 2005
    Cali
    well what ones would be good in dirt because i live on a dirt road
