15,000 mile maintenance ????
Results 1 to 3 of 3
This is a discussion on 15,000 mile maintenance ???? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my car is about to hit the 15,000 mile mark.. i was wondering on the 15 k mile maintenance that ...
    May 2004
    San jose California
    i was wondering on the 15 k mile maintenance that the dealership offers what are they goin to do to my car?.. becuz im thinking doin it my self instead of paying the damn dealer ship big money...
    Registered User bluej20's Avatar
    Jun 2004
    change your oil.....
    also change your gear lube + diff
    switch to synthetic oils ...but do so after some research first on what oil you should use.
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    The dealership will also "check" a lot of stuff like brake pads, tires, filters, etc. If you ask me, going to a dealership and paying them $400 to "check" a bunch of items on a car is just giving them a license to find more stuff to replace so that they can charge you more to replace it.
    In addition to to what bluej20 said, you should check/change your air filter.
    Here is something that BrianH posted back in September:
    Every 3,000 miles or
    three months
    Change engine oil and oil filter
    Check tire pressure and condition
    Check transmission, transaxle, brake, clutch (if applicable), washer and radiator fluid levels
    Every 6,000 to 9,000 miles or six months
    Beginning at 22,500 miles
    All 3,000 mile services, plus:
    Adjust clutch and hillholder (if applicable)
    Rotate tires
    Every15,000 miles or every 18 months
    Rotate tires
    Change air and fuel filters
    Service fuel injectors (beginning at 45,000 miles)
    Test emissions system
    Change automatic transmission fluid (if applicable)
    Check brake linings
    Adjust parking brake
    Check C.V. joints
    Inspect exhaust system
    Check coolant protection level
    Check engine component drive belts and adjust as neccessary
    Inspect cooling system hoses
    Lubricate lock cylinders
    Check exterior light bulbs for proper function
    Check windshield washer and wiper operations
    Every 30,000 miles or
    three years
    All 15,000 mile services, plus:
    Change gear oil
    Flush and service cooling system
    Change brake fluid
    Tune engine
    Change spark plugs (2.5 L and SVX at 60,000 miles)
    Perform induction & intake system service
    Clean throttle assembly and linkage
    Adjust carburetor (if applicable)
    Change distributor cap and rotor (if applicable)
    Engine compression check (2.5 L and SVX if applicable)
    Set engine timing
    Check engine computer for fault codes
    Test/service battery
    Adjust ECVT switches (if applicable)
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
