metal on metal grind sound???
Results 1 to 7 of 7
This is a discussion on metal on metal grind sound??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i believe i just need new brake pads but it makes a constant metal on metal grinding noise when i ...
    Jan 2003
    Indiana
    i believe i just need new brake pads but it makes a constant metal on metal grinding noise when i drive. it actually will stop for a minute when i'm on the brakes. i was told this is the new way they warn you of low brake pads but another friend is worried its a ball joint going out.
    i'm pretty sure i just need to replace my front pads, anyone else have this happen?
    '02 silver sooby
    blitz spec r ebc (7 lbs daily, 15.5 spirited, 17 at the track)...turbo xs rfl...vishnu catless uppipe...turbo xs catless downpipe...turbo xs catless catback...k&n drop in filter...step colder plugs...walbro 255...zex wet kit w/purge (55 shot)
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Describe the sound a little-- is it high pitched squealing? low grinding? ringin tones? thumping?
    It could be brakes... worth pullin a wheel off to look for sure.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    Jan 2003
    Indiana
    its a metal on metal eeeeeeeee.....like scratching on a chalkboard but not so bad.
    loud enough to hear in the cabin with the radio isnt on
    '02 silver sooby
    Feb 2005
    south jersey
    The noise you describe certainly could be brakes.. it would be the first thing I checked.
    Doesn't sound like a ball joint, they usually make a clunking noise.
    Dirty Jersey
    RIP- '02 PSM Wagon
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    More than likely you're right, the pads are just worn. That sounds like the sound the wear indicators make. Just pull the wheels an look. The wear indicators kick in around 1/8" IIRC.
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jun 2004
    just had this issue w/ mine.
    the calipers needed to be cleaned up a bit b/c the pads were sticking.
    once i did that voila! sound all gone.
    Vanitas vanitatum...et omnia vanitas
    Jan 2003
    Indiana
    i think i'm going to clean it up tonight and see if that takes care of it. i had a sound like this coming from my supercharged civic a few years back and i took the wheel off looked around, put it back on and bam problem solved.
    so hopefully theres just some dirt in there, i was hoping it would fix itself but i dont think thats going to happen. hoping i dont have to replace the pads, they havent been on that many miles and they feel fine.
    how much are oem pads for an '02
    '02 silver sooby
