Whats turbo BUCKING?
Results 1 to 4 of 4
This is a discussion on Whats turbo BUCKING? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; whats turbo bucking.... i think i MIGHT have it.......
    Registered User akuma59's Avatar
    Jan 2005
    ^^.BoostiN uP.^^
    Administrator
    May 2003
    Try to explain what's happening. "Turbo bucking" isn't a term I recognize
    Jan 2005
    my turbo just recently started doin some weird thng.... it only happens wen the engine is cold , but it doesnt happen everytime.
    wen i punch the gas, ill feel the turbo kick in and pull then i will feel it kick in a 2nd time as if it kicks in 2 times in a row in the same gear...
    i dont let go of the gas so i knw its not my fault.
    this is usually most noticeable in first nd second gear
    ^^.BoostiN uP.^^
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    It sounds like the annoying behavior of the '04-'05 stock ECU. There's a closed-loop to open-loop fueling transition that happens in which there's a jerky power delivery because of a mismatch in A/F ratio and engine speed. It's normal, but kind of a pain. I guess Cobb or Ecutek improves things.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
