Noise... Dealer "can't replicate"
Results 1 to 9 of 9
This is a discussion on Noise... Dealer "can't replicate" within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Am I surprised? No, the dealer can never find the "noise" that you hear. I think they are all deaf. ...
    Feb 2005
    So. CA
    Anyways, maybe someone here has had the same problem. When the car starts rolling, either in first or even backwards in neutral i hear a "ggrrrrtt" sound that lasts about 1 second and is only heard at a specific speed (approx. 5 mph). I thought is was the clutch, so that is when I tried to let the car roll backwards down my hill in neutral with the clutch out. It still made the noise. The car is not turning, so I don't think the steering has anything to do with it.
    Anyone have any ideas.
    Not clutch judder, either.
    Registered User Oneliner's Avatar
    Dec 2003
    Ottawa
    Does the niose go away after you drive for a bit or does it usually stay? Can you identify the location of the noise? Does it usually happen when the car has been sitting for a while?
    Sep 2004
    Long Island, NY
    I don't know if it's the same noise I hear, but when I turn and either let off the gas down a hill or put it in nuetral it sounds like somthin is falling off my car or rubbing. Hmm not that I think about it, it's probably rubbing.
    96 Honda Integra Type R
    97 Jeep Grand Cherokee (DD)
    02 Subaru WRX (sold)
    www.HirevImports.com
    Brandon@HiRevImports.com
    Registered User bigd's Avatar
    Oct 2004
    Denver
    sure it isn't the brake pads groaning a bit?
    Dave
    01 RS
    Feb 2005
    So. CA
    I should have given more detail.
    The sound happens only once per driving session, for a lack of a better term. It lasts for only a second. Usually occurs after vehicle has been sitting for a while. Use to be only in the morning. Now more frequent. Stop at store, come out 45min. later, it happens. Sounds like something is grinding in right front wheel area. Sounds like gears with no lube on them. Can fluid be low somewhere? Don't think it is brakes. The vehicle has to reach a certain speed for it to happen. I can go 100 feet and it not happen if i am inching along. But if i hit 5 mph it happens.
    Hope that helps.....
    Oct 2004
    Denver
    do you actually feel it in the steering wheel or just hear it? if you feel it at the steering wheel then its proably something to do with the wheel side of things.
    Dave
    01 RS
    Feb 2005
    So. CA
    I just hear it.
    Registered User Mr.Mike's Avatar
    Jan 2005
    midcoast maine
    hard to tell with out hearing it my self, Check your diff fluids and your CV shafts for play, also check wheel berrings.
    I have seen all of the above to make noise at low speed but not high speed.
    hope that helps you out.
    mikey
    Registered User accessdenied's Avatar
    Sep 2004
    PDX
    may sound wiers, but check your exhaust hangers and mounts........i had the same problem, it turned out to be my exhaust where it was near the tranny.a hanger was bent.....lol
