is my new suby broke?
Results 1 to 7 of 7
This is a discussion on is my new suby broke? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have my suby for about 6 months now and i experienced hard start for 3 times while it's like ...
    Nov 2004
    Seattle
    i have my suby for about 6 months now and i experienced hard start for 3 times while it's like 40 degrees F.
    i use mobile 1 5w30 (after 1k mi break in) and just recently (at 11000 mi) changed to redline on tranny.
    does your suby have hard starting once in a while or is it too often in my case?
    3 times in 6 months, that's like once every two months.
    ray
    2005 WRX Wagon Crystal Gray Metallic
    Registered User Fixxxer's Avatar
    Jul 2003
    Lexington, SC
    By "hard start", do you mean that it struggles to turn over, like the battery is low, or it turns over longer than usual before starting?
    If it struggles to turn over, I don't want to say that it's normal, but mine does that from time to time when it's cold out. I've never had it happen in warm weather though. Do you drive the car very far daily? I think part of my problem was that I only had a 7 mile (city) commute to work, and that's really all I used the car for. So the battery was never really getting recharged properly.
    If it turns over fine, but takes longer to actually start, then you might want to try turning the ignition to "on" for a few seconds to let the fuel pump prime before turning the engine over. That's what I do most of the time. Whenever I don't is when it takes a little longer to start.
    Hope this helps!
    -Lee
    Nov 2004
    Seattle
    i takes longer than usual to get started. i usually drive 100 miles per day for work (both ways).
    i'll try to turn the key in ignition for a few sec then start everytime. hope that makes starting smoother.
    thanks for your reply.
    ray
    Quote Originally Posted by Fixxxer
    Hope this helps!
    Jul 2003
    Lexington, SC
    Any time!
    You can actually hear the fuel pump come on when you first turn the key to "on". Just leave it there until you hear the pump cut off, then start the car. If I remember correctly, the key-in-ignition-"ding"-sound will go off about four times by the time the fuel pump is finished.
    -Lee
    Moderator
    Jul 2003
    Maryland
    The wrx is known to have a "weak" battery. You could get a high CCA battery and i'm sure that will help.....listerning for the fuel pump is never a bad idea and I got in the habbit of doing it with every car I drive (menus my work car of course ) I figure if i put the key in and reach around for the seat belt..tap the radio button....then it's time for the car to start fuel primed and ready to go once it idles down.
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    my wrx would have that problem but like fixxxer said, turn the key to ''on'' positioin hear fuel pump and its better. Mine never did that after i got rid of an intake i had. Sti hasnt done that yet **knock on wood**
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    I have had a similar experience, but it hasn't bothered me really. My car is just about as old as yours and I'm right there with you on the mileage. I'm at 12,370 miles since October.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
