O2 sensor question
Results 1 to 8 of 8
This is a discussion on O2 sensor question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys, My GF's WRX developed an unexplained check engine light, so I take it to the dealership.... they say ...
    Jan 2004
    Rosedale, IN
    O2 sensor question
    Hey guys,
    My GF's WRX developed an unexplained check engine light, so I take it to the dealership.... they say that something "chewed through" the wires of the O2 sensor so it isn't coverable under warrenty. Personally I think it is BS and they are trying to screw me out of $450.
    I think this is the rear O2 sensor they are talking about, but I will verify and post again when I get home. I am on the dealerships computer at the moment.
    I assume I can get a new sensor for between $50 and $100.... where can I get one?
    Thanks,
    Keith
    Miss the wifes WRX, but love my Ralliart!
    Jan 2004
    Rosedale, IN
    Update!
    The "chewing" took place under the hood! At this point I am going to try and splice the wires for the sensor under the hood.
    My question now is how do I reset the check engine light after I repair the wires.
    Also.... anyone else have this problem? How do I keep this from happening again?
    Thanks,
    Keith
    Chewed through? Rodents do eat automotive wiring and will even nest in cars, so there is a chance they're correct. Is the car driven much or is it often parked where there are rodents?
    Ask them to show you the damage or see for yourself if there's any evidence that they are correct. However, even if they're not correct, a wire that is physically cut for any reason having nothing to do with the way the car was assembled isn't a warranty issue, it's a matter of damage, so they might still have a point.
    If all else fails try subaruwrxparts.com or some such place, or call a few wrecking yards for a used part.
    - Al Stewart
    Registered User scooby-x's Avatar
    Oct 2004
    State of depression
    Just unhook the battery for like 10 mins and hit the brakes a couple of times to make sure you get all the juice out of the ECU. Then after the 10 mins put the pos cable back on the batter, and voila... reset ecu!
    04 Java Black Pearl - Sleek Eye
    All you see is my license plate... SCOOBY-X
    Quote Originally Posted by GOD The Almighty
    Patrick, you are a complete accident
    Quote Originally Posted by Fourdoor
    Update!
    Thanks,
    Keith
    OK I just saw your last post; I'd responded before you above.
    You can try to splice the wires but if you have an impedance mismatch the readings will not be acceptable and the ECU will still complain. If the ignition is turned on repeatedly without any problem being sensed, the light will be turned off automagically, so if you fix the problem you'll soon see no more light. This has the advantage of not requiring you to do a full reset, which may make the car run a little oddly as the ECU has to relearn from base.
    I've had rodents try to nest in my engine bay on a car I leave parked most of the year. I used rat poison since it was an enclosed garage that nobody but me had access to, and no pets could get in. If this is not the case, then try adopting a cat.
    - Al Stewart
    Registered User Matrix 1193's Avatar
    Mar 2004
    Berlin, Connecticut
    Quote Originally Posted by scooby-x
    you dont need to wait 10 minutes, like 1 minute and it will go away after pumping the brake
    Oct 2004
    State of depression
    Quote Originally Posted by Matrix 1193
    i am just anal
    Jan 2004
    Rosedale, IN
    The car is parked out doors under a car port about a week at a time. My GF and I work at the same place and car pool with one of us driving one week and the other the next week.
    I think I will get some of that bad tasting spray they use to teach puppies not to chew on things and spray down my engine bay.
    Thanks guys,
    Keith
