CEL code .... P0442??
Results 1 to 15 of 18
This is a discussion on CEL code .... P0442?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i finally got my ap and cleared the egt codes that the stage 2 automatically turns off...i liked not having ...
    Aug 2004
    miami, Fl
    i finally got my ap and cleared the egt codes that the stage 2 automatically turns off...i liked not having that annoying CEL in your face all the time...but then yesterday i punched it on 3rd gear to just feel the pull a little and when i let off i threw a CEL i got my ap and read the code and it came up being P0442 which is the evaporative emissions control system leak detected...i tried looking and little hoses and it doesnt sound like any gasket on the up/down pipes...anyone have any other idea what it might be? and where should i look?? any kind of help would be useful im clueless to this point...my car is also kinda bucking when i hit the gas in 2nd and 3rd gear....when i hit target boost...15 lbs
    Mods: ERZ Up/Down pipe, bosal dual tip cat-back, cobb AP stage II
    Registered User Jack's Avatar
    Mar 2003
    North New Jersey, School at Susquehanna University in Pennsylvania (Rt 287, Rt 78, Rt 22, Rt 80)
    Quote Originally Posted by evL`WrX
    i think that might be ur gas cap, check if its tight
    -My name is Tom not Jack
    Check profile for mods
    "I wanted to put a bullet between the eyes of every panda that wouldn't screw to save its species" Fight Club
    Registered User 2point5ohyes's Avatar
    Oct 2004
    williamsville, ny
    man what is goin on lately. my car threw that same code and so did my friends prizm this week. my car is stock tho vs your stage 3 or w/e but im sick of that code. i know my gas cap has always been tight and i dont fuel with it off so i am also
    2000 2.5RS I <3 JDM IH8M
    Aug 2004
    miami, Fl
    lol i tried the gas cap a million times and i havent installed the fuel pump recently so its none of the more common reasons why they've gone off...i searched before i put this up and im clueless to what it is im just going to try to reset the ecu even though i really didnt want to do that...
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Unfortunately, that is the single biggest PITA code in the book. First step gas cap- but if thats not the problem you've got potential for drain valve, purge control solenoid(popular choice), pressure control solenoid, evap canister and of course tank problems... If you're getting running issues w/ that code I'd bet on a solenoid or canister issue.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    boston
    i fixed my cel problem this weekend by removing the evap canister and drain valve and
    removing the electrical tape around the wiring. I found the wire going to the drain valve
    connector completely corroded...just a pile of green copper oxide. This connector
    points up and collects salt, water, and debris from the rear tire. I connected the wire to
    the drain valve and cel went out. Additionally, the hoses going to the drain valve
    are held on by just friction.....mine are very loose and i plan to add a cable tie on them
    i think this cel is a problem waiting to happen on the 2002's.
    j
    Registered User blahblah's Avatar
    Sep 2003
    Chi-cago
    where is the drain valve, evap canister etc. BTW i put a walbro in, any way this could have caused it?
    282 AWHP...267 lb-ft torque.
    2005 WRB WRX Sedan
    "he's a domestic fan with a hunger for rice"
    Oct 2005
    long island
    I know what your problem may be because it happened to me. In front of the alternator there is a blue T fitting that emissions hoses hook up to. It is not rare that one of the sides come out. Check it to make sure before you go removing anything. You will easily be able to find the connector because it is bright blue. Let me know if this is the problem.
    Dec 2005
    UT
    Quote Originally Posted by blahblah
    definitely could be the cause.
    i started getting (then clearing) the CEL everyday on the way home from work a couple of weeks after installing my walbro.
    problem was that the fuel pump access gasket hadn't seated correctly. need to make sure all of the little gasket guide pins pass through the metal cover before you tighten it. i ended up cutting one of them flush to ensure the gasket seated fully.
    no more 0442 CEL!
    Sep 2003
    Chi-cago
    what about that lil metal thing that goes over two of the studs. i put that between the tank and the gasket cuz i didnt wanna deal with it
    2005 WRB WRX Sedan
    Sep 2003
    Chi-cago
    btw i cant find that blue thing. ony thing in front of my alternator is that plastic cover, radiator hose, and grille. im gonna take a look at that fuel pump tomorow...maybe if im not to tired
    2005 WRB WRX Sedan
    Oct 2005
    long island
    The blue T conector is mixed in with other hoses and such. I couldn't find it until I looked hard in the daylight.
    Sep 2003
    Chi-cago
    what other hoses, all i have in front of my alternator is the radiator.
    2005 WRB WRX Sedan
    Sep 2003
    Chi-cago
    just fixed it the gasket was pretty messed up so i think thats it
    2005 WRB WRX Sedan
    Oct 2005
    long island
    Let me know if thats it. If it isn't I will take a picture and post it.
