Battery acid removal
Results 1 to 9 of 9
This is a discussion on Battery acid removal within the Exterior and Appearance forums, part of the Tutorials & DIY category; do you guys know a way to get battery acid off parts, like intake manifold and stuff?...
    Jan 2005
    lenexa, ks
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    I actually just pressure sprayed mine at the car wash. It came right off. Just go to the carwash, switch on the soap, wash the whole car until the soap gets hot. Then you can spray your engine bay with HOT water and not have to worry about cracking anything because of the temperature shock.
    2005 CGM STi
    Administrator
    May 2003
    Neutralize the acid with baking soda, and wash off with a hose or pressure washer.
    Jan 2005
    lenexa, ks
    mine has been on there for some time, i was thinking of sanding it off
    May 2004
    Well if you haven't tried washing it off you should do that first. I got my car used and there was battery acid on there from who knows when. It looked ancient. The pressure hose took it right off. No sense in doing more work than needed, right?
    2005 CGM STi
    Jan 2005
    lenexa, ks
    should i do baking soda before spraying it off?
    Administrator
    May 2003
    Quote Originally Posted by wrxraaca
    If the acid is old, the baking soda wont do any good.
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Yep.......
    Works when ya get that **** in your fingernails too!
    Shotgun
    "Speed Kills......But so do Strokes,...Sign your donar card"
    Registered User Chudv23's Avatar
    Mar 2011
    Tulsa
    Windex and a wire brush, or coke and a wire brush!
