Fog Lights ON without the headlights
Results 1 to 15 of 26
This is a discussion on Fog Lights ON without the headlights within the Exterior and Appearance forums, part of the Tutorials & DIY category; Ok, I plan on turning off the Daytime running lights here from the scooby link. But the question is, has ...
    Registered User Sherb's Avatar
    Jul 2001
    KY
    Angry Fog Lights ON without the headlights
    Ok, I plan on turning off the Daytime running lights here from the scooby link. But the question is, has anyone modified the fog lights to just turn on with the parking lights?
    2002 Rally Blue WRX - Few mods
    dowell2244
    Thumbs up
    No, but let me know when you find out how! I'm just as curious as you are. I wish you could run them completely independently, even with the high beams. Makes the backroads alot funner too I'm sure it can be done somehow, but I'll let somebody else figure it out first. Later
    Keeferno
    Post
    I haven't done it to my WRX yet but I wired a simple switch for my eclipse and it's quite nice. I'll probably do the same thing to the WRX when I get a chance and i'll let you guys know if I do.
    WRX07444
    Cool
    I had the same problem with my dodge ram pick-up. All I did was cut a pin off of one of the relays that control headlights and fog lights and presto I had independant control.
    Now the question is can we do the same sort of thing on the wrx?
    I hope someone posts a solution quick!
    Registered User jorge02wrx's Avatar
    Apr 2001
    San Diego, CA
    Post
    you can get them running without having to turn on the lights all the way by following instructions listed on this link ---->fog light mod
    The problem I see is that the Day time running lights will still be on.
    I'll try it but i'll have to find the constant wire behind the fog light switch first.
    Jorge F.
    Auto Concept Elite
    Jul 2001
    KY
    Post
    I don't know what the daytime runnning lights have to do with the fog lights but some pointers on that link seems good. I would use a voltmeter and make sure what wire turns on the ciruit. If you look back in history, there is a link on here that shows that all you have to do to turn of the daytime running lights is by unplugging a harness. My fogs/parking/head lights still work so by replacing the wire from the headlights to the fog lights, it should work. The real problem is taking off the dash without breaking anything.
    Sergeant V
    Post
    Here's a link to another
    fog light mod
    Jul 2001
    KY
    Post
    Thanks for the link Sergeant and I've successfully did this mod last night. It is awesome to have the fog lights ON with just the parking lights. I skipped some steps as I wired the the fog light wire turn on relay to the illumination fuse rather than taking the fuse box apart. I will post my version on the modification:
    1. Disconnect battery if you don't want to take any risks.
    2. Find the fuse box located on the lower left of the dash, you have to takeoff the coin holder (pulls right out when open)
    3. To the right of the fuse box is a black case holding all the relays, take it off.(you can do this by pressing in the 3 black trim pieces with a needle nose pliers by getting under the dash from the side).
    4. Locate the 4th relay down from the top of the black case(this is the fog relay) and locate the Red w/Green stripe wire on the backside.
    5. Cut this wire and tape the wire coming from the dash.
    6. Extend the Red/green wire going into the relay with a 1 foot wire (14/16 gauge).
    7. Take that wire and wrap it around the illumination fuse and the place the fuse back in the fuse box
    8. Tape up all connections and test it out before you put everything back togethor.
    This mod will let you turn your fogs on with just the parking lights and/or the High Beams.
    Aug 2001
    Land of earth-tone stucco, Irvine Ca.
    Thumbs up
    Thanks Sherb, your method worked great! Very easy and fast.
    2002 WR Blue WRX
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    I am going to be doing this foglight mod in preparation for the "Vernal Equinox" Road Rally in two weeks. Hopefully high-beam and fogs will be enough light for the super dark roads these rallies are held on. I might be upgrading my bulbs as well.
    -Jim
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    Get a pair of lights that have a "driving light" pattern. The difference is a narrower beam, but no vertical cut-off, allowing the beam to go higher & farther down. Jim you may recall my last car had driving lights.
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    My concern with this mod, has always been that you have a greater danger of running the battery flat, since it encourages the use of the parking lights which will stay on when the key is removed. Does this mod at least prevent the fogs from staying on with the parking lights when the key is removed?
    Here's a thought: Are the oem foglights the sealed beam type, or can you replace the bulbs? I haven't checked on this, but if you can remove the bulb then it seems like there might be a possibility of converting them into driving lamps..?!? Anybody?
    -Pace
    Registered User refuse2growup's Avatar
    Oct 2001
    Sacramento, CA
    The OEM foglights use and H3 bulb.
    As for the foglight mod, I still dont use the parking light switch. Just turn the headlight switch one notch instead of two. And even with the foglight mod, if done correctly, they still turn off with the key.
    Matt (refuse2growup)
    2002 WRX Wagon, Alpine White
    - Kartboy shifter and bushings - Subaru column mounted boost guage - Turbo XS MBC - AEM Cold Air Intake - Flowmaster Axle Back - Whiteline Rear Strut Tower Brace - Whiteline Front Strut Tower Brace - Subaru Sedan Rear Sway Bar - Whiteline solid sway bar end links front & rear - Whiteline ALK - Replica WRC headlights
    Jul 2001
    KY
    The steps listed above shows:
    In step 7, whatever type of power you wire will determine when the fog lights can be turned on. If you use the battery power/fuse, the fogs can be turned on at anytime. Wrapping it to the ignition power/fuse will allow power to the fogs at the ignition level only. And ofcourse there is also an accessory power if one chooses.
    Jun 2005
    ct
    i just did this today following your steps. took about 10 minutes, and real easy to do. thanks for the write up
    vf22 Stage IIII wagon of DOOM
