Hella Supertone Fuse Amperage
Results 1 to 3 of 3
This is a discussion on Hella Supertone Fuse Amperage within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; So, I installed my supertone horns. I'm using the included relay for a "cleaner" amount of power to the horns. ...
    Mar 2002
    East Stroudsburg, PA
    So, I installed my supertone horns. I'm using the included relay for a "cleaner" amount of power to the horns. As per "good practices", I fused the 12v source as close as possible to the battery terminal. I first tried a 5v fuse. I promptly blew it by laying on the horn. I tried a 10 amp fuse, blew it fairly quick too (although it lasted longer). Just wondering what fuse amperage I should be putting in here, and trying to determine whether I've got another problem. I have a fluke multimeter that can measure amperage (tried placing it into the fuse holder, and held down the horn, didn't measure anything).
    So, my 2 questions (repeated sort of)
    How do I measure the amperage of the two horns using a fluke series 73 III multimeter
    What amperage draw should I expect from the horns?
    Mar 2002
    FYI, I've *always* had problems w/ measuring amperage.
    Registered User dielectric's Avatar
    Mar 2003
    Palatine, IL
    The original horn should have a 15A fuse. You might try that, or 20A.
    FWIW, I don't think all this business with the relay is necessary. There's one there for the stock horns already, and I can't imagine any reason to uprate that relay.
    To actually measure the amperage with a multimeter, you need to hook the meter up in series with the load. So, you need to disconnect the circuit at some point, preferably a connector. Put one test lead in each half of the connector and test. Make sure your meter can handle at least 20A.
