JDM Projectors
Results 1 to 15 of 22
This is a discussion on JDM Projectors within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Stupid question. I have been wanting to get the Bug eye JDM projectors for my car, but I have read ...
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    Red face JDM Projectors
    Stupid question. I have been wanting to get the Bug eye JDM projectors for my car, but I have read that since they're JDM they would blind the oncoming traffic. So I was wondering if there is any way to position the projectors or make them so that the cut off angles off to the left?
    Thanks,
    Corey
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    Its not as bad as some people think. I have the JDM HIDs and rarely get flashed. I have then aimed straight out and they angle up very slightly at the very left side of the beam.
    People I know have both seen my lights from the oncoming traffic perspective and in thier rear view mirror. They all say it is not as bright and glaring as some of the USDM HIDs. The cutoff is very precise.
    If I dont make any sense it cause Im high on oxycodone. Root canals such ass.
    No one will truely be free until nerd persecution ends.
    May 2004
    Ok, cool. Now I just need to save up some money. Yeah, I'm sure root canals do suck from what I hear. I had my wisdom teeth pulled... I hated it. Thanks for the info and I hope you get better!
    Registered User EvilCerealBoX's Avatar
    Nov 2003
    ATX
    goto ravspec.com get the GDA WRC projector housings (like $150) and buy some HID bulbs (like 60-80 for a pair?)... thats what i'm gonna do, it'll kick ass
    May 2004
    I'll check into that. I thought HID bulbs cost more than that... Thanks for the info.
    Oct 2002
    Beaverton OR
    HID kits go for about $300- $400. Prolly more if you want a good quality kit.
    I think the bulbs in my housings go for about $120 each. They are OEM Panasonic bulbs. They are also expected to outlast the car so I shouldn't have to replace them.
    Registered User spacemanspiff's Avatar
    Apr 2003
    Austin it is
    consider getting EDM lights. same look with left hand drive light pattern. not cheap tho'...
    A lot of power is good, more is better, and too much is perfect. I mean, if less is more, think how much more more is...
    May 2004
    Yeah, I saw those too. They're only $200 more lol. I think I'll just go with the JDM's.
    gfx
    gfx is offline
    Registered User gfx's Avatar
    May 2003
    Pittsburgh, PA
    I have the JDMs and have *never* gotten flashed. They are fine.
    BTW you don't need HIDs.. they are only for the low beams anyways and the stock low beams are bright enough. HIDs would be for show only IMO. Not saying I don't want them, though
    2003 5MT WRB WRX Sedan
    Cobb stage 2.5 w/ VF30, Stoptech BBK, JDM STI front/rear seats, Mattjk LCD setup, JDM headlights w/ McColluch 6000k HIDs, GReddy EVO, 17x8" Gold Rota Torques, Eibach Pro-kit
    http://www.cardomain.com/id/gfxwrx
    My car shots taken with my Canon 300D dSLR
    May 2004
    Ok, thats probably going to be my next mod. I just need to save up some money. I like them because they make the car look better, plus they're better headlights. A good investment IMO.
    May 2004
    While I'm on the subject of JDM's... Do you need to buy a different harness for them to wire into? Or do they just wire up to the stock harness?
    Thanks
    Oct 2002
    Beaverton OR
    You have to have a harness for the JDM or EDM. none of them will plug into your stock harness. Check out www.cc-b.com to buy a harness (wussy way) or make your own. If your even slightly creative you can easily figure it out. I did. took an hour to make my own harnesses and figure out how to wire them.
    gfx
    gfx is offline
    May 2003
    Pittsburgh, PA
    I got the wiring harness from cc-b.com
    It's perfect.. just install spade connectors on the pieces that will install into the JDM headlight and the rest is plug and play. I had a problem where the 9007 connector was too long, however, but I just trimmed it and all is well.
    May 2004
    Nice. How much do the harness' run each?
    gfx
    gfx is offline
    May 2003
    Pittsburgh, PA
    http://cc-b.com/Merchant2/merchant.m...Code=84001FEHA
    $45 total.. but I didn't use those blue clips. On the loose wires I attached the spade connectors. The big blue thing is the connector I had to trim.
