McCulloch HID Light Install
Results 1 to 4 of 4
This is a discussion on McCulloch HID Light Install within the Exterior and Appearance forums, part of the Tutorials & DIY category; 2003 Subaru Impreza - 8000K 9007 McCulloch HID Install Tools: 1 HID Kit 10MM Socket Wrench Flat Head Screw Driver ...
    Registered User Subie2.5RS2003's Avatar
    Aug 2003
    Brooklyn -- UAlbany -- Poconos
    Tools:
    1 HID Kit
    10MM Socket Wrench
    1) It is recommended to unplug your battery, but not always needed.
    2) Remove your grille, but pulling off the tabs 4 of them keep the stock grille in place and 2 tabs keep the body colored pieces in place which go between the grille and head lamp (2 on each)
    3a) Remove your airbox/intake, with 10MM screws, (WRX Models 2 screws, RS Models 1 Screw) connected to the area where the grille was.
    3b) If you would like to remove your head light plase see step 9 For instructions
    4) Remove stock bulbs, but twisting dust caps and then pulling out, then remove the old bulbs from their harness.
    5a) Connect the stock harness with the harness connector which comes in the kit.
    5b) Make sure to connect the black and white wires in to the harness which comes with the kit
    6) Connect and secure all wiring using the zip ties and double sided tape provided. Please select a secure area where the wires and ballast do not come in contact with any moving or high heat parts.
    7) Place HID Bulb in to Headlight and then secure with dust cap. Then connect the 2 wires from the bulb to the 2 wires which come from the ballast
    8) Check Bulb if it works, make sure to start the car first before you turn on the lights.
    9) Remove drivers side head light, 3 10 MM screws, 1 located on the fender on top of the head light and 2 located on the passanger side of the head light connect to the black plastic holder.
    10) Repeat steps 4-8
    11) Allow head lights to sit in the on poistion for 10 minutes with the engine running.
    Trouble Shooting:
    - Lights do not turn on: try upgrading to 20A Fuses
    - Lights Strobe: check wiring and make sure Day time running lights are disconnected.
    - One light does not work: try it on the other side and double check wiring.
    Before:
    Between:
    After:
    SQC - 189
    Quote Originally Posted by scooby-x
    hmmm I see a correlation between all those items... but wow man a hamster? I prefer gerbils my self cus you can keep a hold of their tail so they dont "get lost", ya know... hehe it tickles
    Registered User 03redwrx's Avatar
    Mar 2006
    Tacoma,WA
    where did you get the hid kit at and how much
    Feb 2006
    sorry to brign this thread back from the dead but im trying to isntall this kit but im having some trouble
    i followed the full tutorial, but no mattter what the lights just strobe. I tried switchign around the wires in the harness but still no luck
    i disconnected boht DRL connecters so i dont think thats the problem
    thanks!
    Mar 2007
    Smile we can supply Auto HID xenon light
    hello,
    anyone who want to buy Auto HID Light can contact us,we have all the type of this HID light,including(H1,H3,H4,H7,H8,H9,H11,H13,9004,900 5,9006,9007,D2C,D2R,D2S),and all the products are new with high quality and competitive price.we can promise give you our best price and service if you buy from us.
