Results 1 to 2 of 2
This is a discussion on EDM projector alignment??? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; all right, so I got my EDM lights in and the low bealm pattern is WAY high. For those with ...
    Feb 2003
    orange county, Ca.
    For those with either JDM or EDM projectors....how did you align yours? How far away from the wall were you? how many turns on the "lower" adjustment did you have to make??
    any help would be appreciated. I did a search but it really didnt come up with the results I needed.
    thanks.
    "Failure is only an option for those who try".
    Lower the beams so that they only hit the top of the trunk of a car 20 m ahead of you on level ground, not the rearview mirror. There are ways to do it on a wall but I've found the follow-this-car method the most practical. You'll end up with a beam that's as high as possible without being a traffic problem.
