Results 1 to 10 of 10
This is a discussion on Morette Brightstar H7 HID kit install within the Exterior and Appearance forums, part of the Tutorials & DIY category; Here's the basic installation guide for the Brightstar H7 HID kits for the Morette headlights. The installation was very simple ...
    Administrator BlazinWRX's Avatar
    Apr 2001
    Irvine, CA 92620
    The installation was very simple and it took only about 40 minutes. Please follow all installation instructions on the instructions that came with the kit. I will only go over the WRX /Morette specific aspects of the installation.
    1. Make sure your power is turned off
    2. Remove your battery
    3. Remove the air intake duct (the plastic vent right above your grill)
    4. Remove/Unplug your regular H7 bulbs
    5. Carefully put in the HID H7 Bulbs (I believe the metal lampshade actaully points up for the Morettes even though the instruction says they're suppose to point down. Regardless of that the result was fine)
    6. Connect the headlights to the igniter
    7. Connect the igniter ot the ballast
    8. Connect the harness to the ballast
    9. Connect the stocket of the original headlight to the harness. (see picture)
    For the right headlight.
    10. Screw a metal mounting plate on the ballast for the right headlight.
    11. Bend the part of the mounting plate up 90 degrees so you can screw it in the 6mm hole. Note that the screws are provided in the kit.
    For the left headlight.
    12. Repeat steps 6-9
    13. Mount the ballast right between the flat surface between your headlight unit and the battery with the double sided tape provided.
    14. Stick the ignitor on the flat area between the headlight unit and the grill, there should be plenty of space.
    Vuala you're done. Feel free to let me know if you have any questions regarding this install.
    Tim
    Admin
    Apr 2001
    Irvine, CA 92620
    Step 9: Connect the stocket of the original headlight to the harness. Wrap the connection with some electric tape after.
    Tim
    Admin
    Apr 2001
    Irvine, CA 92620
    This is the right headlight. Note the bend on the metal plate and where you can actaully screw the ballast in securely.
    Tim
    Admin
    Apr 2001
    Irvine, CA 92620
    Here are the Morettes after the install
    Tim
    Admin
    Apr 2001
    Irvine, CA 92620
    And the beam pattern
    Tim
    Admin
    Registered User paragonwrx's Avatar
    Sep 2003
    Downers Grove, IL
    BlazinWRX, Nice install. I personally love the HID lights. It pretty much screams here comes something expensive and probably fast.
    Apr 2001
    Irvine, CA 92620
    Thank you Did you get a set yourself?
    Tim
    Admin
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    I have these HIDs in my Prodrive UK300 lights (high and low beam). H7 for both housings on the UK300s. I will post some pics shortly. I found a different place to mount the ballasts as I had to hide 4 of them!
    Cheers,
    Andrew
    Apr 2001
    Irvine, CA 92620
    Sweet I want to see those pictures Also I want to know where you mounted the ballasts.
    Tim
    Admin
    Sep 2007
    Boston
    Morette headlights
    Where can i buy morette headlights
