---<{{{The Official Wagon Thread}}}>--- - Page 96
Page 96 of 134 FirstFirst ... 468687888990919293949596979899100101102103104105106 ... LastLast
Results 1,426 to 1,440 of 1996
This is a discussion on ---<{{{The Official Wagon Thread}}}>--- within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Hi guys, I just manage to attach a pic of my wagon while on the track last week. I was ...
  1. #1426
    Registered User IWagon's Avatar
    Nov 2007
    Little Red Dot
    Hi guys,
    I was trying out the BC BR coilover which I have fix.
    Hope I got the attachment correct!
  3. #1427
    Aug 2006
    bay area
    06 wagon of mine
  4. #1428
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    hmm I think I've scene this before
    2002 wagon 83k miles
    perrin short ram, inlet & fmic, perrin / samco hoses and fuel rails, bosal dp. erz upp, borla catback, sti ra gears w/ stock 5th, act clutch & fly, vf30, AP, perrin end links, critical cooling kit, hks bov, perrin 4pot brakes, rota wheels, hid w/ levals
    Racenut3.0 - said
    "The worst thing about the AP is it did not come with any fairy dust. I wanna fly dammit!"
  6. #1429
    Sep 2004
    Moline IL
    BigSky, Thanks alot with the hookup at Alexperformance. I got every thing on today. The ride quality is awsome with the RCE wagon springs. I have one issue right now, the front right is like popping/clunking. I havn't had time to check everything out yet. Just trying to get the car to settle in abit to get the ride height right. These springs are alot nicer the the Tein H tech's I just took off.
    Brian
    Rev'n Seven Motorsports And Quad City Boxer Four
    02 WRX Wagon 13.6@99mph 1.90 60 foot
  7. #1430
    Feb 2005
    Lynnwood, WA
    Just washed !
    Updated engine pics
    My new prodrive steering wheel and quick release combo!
    Thanks to kito and Dom
    ahh... trackdays in Cali.
  8. #1431
    Jul 2001
    Plains of Eastern Montana
    Quote Originally Posted by revnseven View Post
    Brian
    Brian some things to check: insure the top nut is fully seated, this is very common for it not to be- just a slight gap will cause a clunk. I'd suggest putting a air gun to it (suspension fully loaded)- just a couple of short zaps (it doesn't take much- too much and guys have actually sheared the strut shaft off!!!!!)
    sway links up front, I have often found noises I thought for certain were coming from the strut instead be from the sway links. an easy test is simply undo one side of the sway bar and drive the offending roads/bumps and see if still makes noise- if it does cross sway links off the list.
    sometimes a mis-assembly of the strut can make noise- getting the domed washer upside down, getting the domed washer under the upper spring perch (I did this once ), not getting the upper perch lined up correctly- the middle hole of the upper perch should be centered on the strut and faced directly outward.
    occasionally the subframe comes loose and will clunk, even the brake calipers- go through my chassis torque setting tutorial and insure everything is torqued correctly
    hopefully one of those will do the trick
    ^^ gents the silver and gray wagons w/ the black rims look good
    Mike
  9. #1432
    Sep 2004
    Moline IL
    I will give them a shot. I have a 19.2 volt electric impact I can use or go to my dads. I made my own spacers in the bottom of the strut to get more bump stroke, due to cutting to much off the tubes. Might pull that one off and see if it has bottomed out and make a new one at work on monday. I haven't touched the front swaybar yet, I do have a new whiteline bar for the front and will be getting new endlinks once I get it on.
    It rides so much nicer with this setup then the Dspecs and the H Techs. So I will let you know what I find out.
    Brian
  10. #1433
    Registered User Khayman_13's Avatar
    Jan 2008
    Weatherford, Texas, United States
    Heres my beast:
    Cobb 2, megan header and up-pipe, catless turbo xs rfl tbe, and other stuff...
  11. #1434
    Registered User WRXWagon88's Avatar
    Mar 2007
    South Dade
    Wink Nice!!!
    Quote Originally Posted by IWagon View Post
    Hi guys,
    Brother that Red is SWEET!
    Is that the Prodrive Lip, and how do those coilover work for you??
    Really hot ride!!
  12. #1435
    Registered User Cirrus's Avatar
    Jun 2007
    Seattle
    No one's posted here for a while. Time to change that.
    Two pics, my "new" (to me at least) '05 Wagon:
    And my bud's '91 Legacy STi Swap (powertrain, suspension, the works):
    2005 Silver WRX Wagon - picked up 03/20/08!
    My Photography Website <-- If you live in the Pacific Northwest and want some sick pics of your car - hit me up.
  13. #1436
    Jul 2001
    welcome aboard fellow wagoneer
  14. #1437
    Sep 2004
    West of the Mississippi
    hey big,
    you know the part number(s) for the koni inserts?
  15. #1438
    Jul 2001
    yup
    fronts 8610-1351 02-07
    rears 8610-1408 02-03 OR rears 8610-1440 04-07
    rears are dependent on what style springs your going to run 02/03 or 04+
    the housings can come from any year - I'm running 04+ rears in 02 housings
    Mike
  16. #1439
    Sep 2004
    thx mike! they're 04 housings w/prodrive springs.
  17. #1440
    Registered User RoundEye's Avatar
    Jul 2007
    Norristown
    Here is my 03 wagon
