---<{{{The Official Wagon Thread}}}>--- - Page 120
This is a discussion on ---<{{{The Official Wagon Thread}}}>--- within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Bugeyez Should set it off nicely IMO Those will do the job.....
  1. #1786
    Hammerdown Mod of Thunder josnroh's Avatar
    Feb 2003
    oHIo
    Quote Originally Posted by Bugeyez View Post
    JOE/Flyin' Under the Radar
    2015 Buckeye Boxer WRX
    2003 Hammerdown Wagon WRX(sold)
    1983 GL-10 Wagon (RIP)
    Sometimes you get the best light from a burning bridge.
    http://badges.fuelly.com/images/sig-us/282947.png
  3. #1787
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    oh thank god. Those wheels HAVE to go. With the new wheels, the wagon will look slick
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  4. #1788
    May 2008
    Florida Panhandle
    18x9's will not even be CLOSE to fitting the wagon.
    Rolling fenders wont help.. you'll need to pull the fenders, and even then it'll probably be borderline.
    Look into a 17x8 or a 18x7.5 wheel... they'll be more likely to fit your wagon.
    I see pictures of 17x9's on wagons. I just want to put as much tire meat to the ground as possible. You have any pictures of a 17x8 w/245's on it? I am just afraid of the sidewall folding over on itself when taking a hard corner. Also, what sidewall size would you want for 245's on a 17x8? Any input on 18x8 (as to what's a good size tire to run on it, sidewall specs included).
  6. #1789
    zax
    zax is online now
    Nov 2008
    Quote Originally Posted by profall View Post
    Keep in mind that larger wheels will begin to decrease car performance... there is a point of diminishing returns. Sure, larger tires will help give the car better grip in the turns, but increased contact area will decrease acceleration and top speed (more rolling friction and unsprung weight), as well as significantly poorer fuel economy.
    Facebook me here
  7. #1790
    Jul 2001
    Plains of Eastern Montana
    17x8's are the defacto wheel size for STX class for the WRX and lots of wagons running in that class- most us ran 235/40/17's as there was a pretty good gearing advantage w/ the shorter tire (and most offerings ran on the wide side anyways)
    in 245, the 245/40/17 would be the best choice IMO-just a smidge shorter than oe height- 245/45 is a little tall IMO
    w/ the right offset, the right ride height, the right spring rates, the right alignment- I think 17x9's and 245/40's would be doable w/ just a fender roll- won't be easy, but I think doable
  8. #1791
    NJO
    NJO is offline
    Registered User NJO's Avatar
    Oct 2007
    SL,UT
    ive seen a wrx wagon at MMP on day with "just rolled fenders" on some custom 17 inch steelies done by diamond racing wheels i think that cleared the coilover by about 1 or 2 mm and the fender by about 1 or 2 mm and he ran 255s he did have sedan front fenders but in the rear i measured mine today and 255 didnt look to possible... i can only imagine he has the fenders pulled some too, but still thats a wide tire on a wagon. he was an older guy that was way in to tracking and i told him to join so maybe we will see him aorund one day
    EX BUGEYE MAFIA #193
    1996 Legacy Outback
    Ej20 swap/ with ALL supporting parts
    intake/turbo inlet/vf39/big tmic/headers/uppipe/downpipe/straight pipe/walbro fp/modded stock injectors/ and too much more
  9. #1792
    Jul 2001
    ^ there was a fellow on nasioc that posted up some 255's- definitely on the tight side
    when you get near the raggedy edge of fitment there is no guarantee (except the fact that your going to have some work ahead of you )
  10. #1793
    May 2008
    Florida Panhandle
    Well, I think I am going to run 17x8's as it seems to be the best choice in terms of performance and price. Still not sure if I should run 245 or 235's on the 17x8. The largest tires i've ever had on a car was 225's. Once I fix some of the problems with my car and get it tuned, I am going to be putting down close to 400WHP so I really need to get rid of the crappy 205's on there right now for safety's sake.
    I've pretty much decided on these brand/design. http://www.vividracing.com/catalog/w...6398_6512.html
    They are re-branded A-Tech wheels (Japanese Company) and they are lighter, cheaper, and stronger then say a rota of the same size/design. Now the question is, Bronze or Gunmetal on a PSM Wagon.
  11. #1794
    zax
    zax is online now
    Nov 2008
    wow. what mods? are you still running on the stock tranny?
    Facebook me here
  12. #1795
    May 2008
    Florida Panhandle
    Crawford S2 Short Block and JDM V7 Spec C heads (Large Port). Running an FPGreen on it at the moment.
    I have the JDM STI RA Gearset in my tranny at the moment. Still have the 3.9 front and rear. I know it's not a bulletproof tranny, but it's better then the stock 02 tranny and as long as I take care of it, it should be good for a while. I know it'll blow up on me one day and I eventually plan on doing a 6 speed swap or PPG gearbox.
  13. #1796
    Registered User the mike's Avatar
    Dec 2002
    Delran, NJ.
    I am currently running 17x8 with 245/40's on my wagon without incident at STOCK height. Doesn't look like it's going to be a problem to lower the car. Maybe a small roll of the lip.
    I ran STi BBS's with 245/40's on Eibach prokit springs without a problem through EVERYTHING.
    Creeping up on creeping for a decade.
    Bugeye Mafia V2 #322
  14. #1797
    zax
    zax is online now
    Nov 2008
    nice! If it were me, I'd forgo the 6spd in favor of the PPG 1-4 w/ PPG front diff and R180 ring & pinion in the R160 case. That's my vote
    Facebook me here
  15. #1798
    May 2008
    Florida Panhandle
    Quote Originally Posted by the mike View Post
    You have any pics?
  16. #1799
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    This. I'm seriously considering this option when its time to do some engine work that the trans won't like.
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  17. #1800
    Dec 2002
    Delran, NJ.
    The only one I have at the moment...
