URGENT* DIY gone wrong!
Results 1 to 15 of 27
This is a discussion on URGENT* DIY gone wrong! within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Okay so I tried the DIY mod for the foglight mod right now as shown here http://www.clubwrx.net/forums/showth...p?t=899&page=2 on my 07 ...
    Registered User heyitznosaj's Avatar
    Apr 2007
    Quincy, MA
    Red face URGENT* DIY gone wrong!
    Fog Lights ON without the headlights on my 07 WRX. I cut the red/green wire and wrapped it around my illumination fuse and the parkinglight/taillight fuse with no sucess. I didn't get a chance to put the red/green wire back together because it started to rain but I noticed that my taillights, interior lights, and parkinglights have all stopped working. Is this normal?
    2007 OBP WRX LTD
    Cobb Accessport v2 Stage 2
    McCulloch 5000K HIDs h7
    DDM Slim 3000K HIDs h3
    HKS Carbon-Ti Exhaust
    Whiteline 24mm adj. FSB
    Invidia v2 bellmouth downpipe
    Pioneer Avic-D3 w/ CD-I200 Ipod cable & CD-R55 remote
    Nov 2005
    Central Florida
    u might have blown a fuse
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Apr 2007
    Quincy, MA
    I checked my fuses and they all seem to be perfectly fine. Is it possible that the interior lights, foglights, and parkinglights are linked to that one green and red wire?
    2007 OBP WRX LTD
    Registered User wrxit's Avatar
    Oct 2004
    Cape Cod/Waltham, MA
    Reconnect the wires, see what happens, if nothing then probably fuse, when the rain stops just run through some trial and error, it can only be so many things, you cut an electrical wire, and now you have an electrical problem, I think you will figure it out in no time. Also follow the wires in both directions for as far as you can and see if you find anything that way. Best of luck
    Registered User EvohuntinWRX's Avatar
    Aug 2006
    VA
    Quote Originally Posted by heyitznosaj View Post
    WOW that sucks man...try searching on Nasioc. have you tried reconnecting the wires? maybe resoder them?
    2007 VF'39ed WRX in OBP...
    VF39/supporting mods
    Hawk-Eye Alliance #61
    Apr 2007
    Quincy, MA
    We'll todays things went from bad to worse. I thought I had found my mistake and made an attempt to finish doing the foglight mod. I followed these directions
    http://img452.imageshack.us/img452/1...ightmodnn3.jpg and not only did it not work but I had to ghetto rig two wires back together now instead of one. The headlights and foglights are now working but I definetly need someone to professionally fix these wires because there are basically held together with electrical tape. My taillights and interior lights however are still not working. I think when I wrapped the wire around the parkinglight/taillight fuse (5) and int. illumination fuse (12) and stuck it back in the slot, I may have overloaded something. Anyone have any ideas on how to fix this or where I should take it so that it won't cost an arm and a leg.
    2007 OBP WRX LTD
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Take pics. Pics are worth 1000 posts.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Here is a hint...
    Take it completely back apart to no electrical mod... Redo what was done factory.. Drive car as car inteded. Mod performance stuff/non electrical issue.
    Lead Wrench @ WTF Tuning, LLC
    Apr 2007
    Quincy, MA
    Everything is basically back to stock at the moment with the exception of the electrical tape holding the wires together. My problem is that the interior lights, parkinglights, and interior lights are not coming on.
    2007 OBP WRX LTD
    Jun 2006
    Nor Cal
    Gotta be a fuse dude.
    Check the fuse box under the dash, and the one in the engine bay.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Apr 2007
    Quincy, MA
    Nope, that was the first thing I checked and they are perfectly fine. The thing is that I wrapped the red/green wire from the foglights around the fuse and stuck it in the slot.
    2007 OBP WRX LTD
    Jun 2006
    Nor Cal
    Use the camera in your avatar and show me. Ibeavisuallearner.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Dec 2004
    Medford, Oregon
    You may have fried your multiplex doing that. Never a good thing to wrap a bare wire around a fuse and stick it back in the slot..
    Do you have a test light? If so ground it, and check to make sure it lights up on both sides of each and every fuse in that car. If it doesnt, replace the fuse. Im sure you may find one bad even tho it looks good. If not you may have fried the lighting switch or the multiplex..
    Jun 2006
    Nor Cal
    Quote Originally Posted by LPPTundWRX View Post
    I know its like pouring salt in the wound, but I gotta say it: Why do people insist on saving $50 by rigging 50 cents worth of shtick on their $29000 car? You end up spending $1000 to save $50. If you aren't capable/comfortable doing a mod take it to someone who is.
    Pull each fuse out and check again. Pray to god you didn't fry your wiring harness. And for god sake go take pics and post them here.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Apr 2007
    Quincy, MA
    Hope this helps. This is what I did before but it is back to stock form right now.
    2007 OBP WRX LTD
