DIY: JDM side blinker
Results 1 to 8 of 8
This is a discussion on DIY: JDM side blinker within the Exterior and Appearance forums, part of the Tutorials & DIY category; Spent about 2 hours installing JDM side blinkers today. This intall was not as bad as I thought. You just ...
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    Spent about 2 hours installing JDM side blinkers today. This intall was not as bad as I thought. You just need to be brave enough to put a hole in a perfectly nice fender.
    Tools/parts you need:
    - Drill bits in many different sizes (up to 1/4") to gradually make hole bigger.
    - Dibbler ($4 from Radio Shack) which is used to cut away fender metal.
    - Template: I downloaded from here:
    http://www.speerschong.com/ron/sti/s...r-template.pdf
    - Butt connectors and speaker wires from Radio Shack.
    - Electrical tape
    - Windshield wiper blade insert or metal hanger
    Here are the pictures.
    Here are some pictures from today's install. Hardest thing was finding a place that sells nibbler as many places did not even know what nibbler was (Lowe's, Auto zone, Sears, etc).
    I ordered a set of JDM blinkers from suby dude for around $80 shipped. These come with replaceable bulbs.
    Carefully align template on the fender and use masking tape to secure it. Measure 3x before you start drilling.
    Starting with the smallest drill bit you have, carefully increase the size of hole until you reach 1/4" drill bit.
    Time to cut fenders using nibbler
    Use wrench to flatten end of butt connector. I did not have to use soldering gun, which saved time and effort.
    Mar 2002
    NY
    It's time to use a long wire to run wires from side blinker to OEM blinker. Splice OEM wires and make good connections. Soldering may help here although it's optional.
    I used OEM touch up paint to prevent rust from forming on cut surface.
    Jan 2005
    San Francisco
    Great job!
    2 questions:
    1. did you use a template to cut into your fender & what did you use to cut through the fender?
    2. did you remove the wheels and fender liners when doing this?
    Thanks!
    Mar 2002
    NY
    you use template and I did not have to remove wheel/fender liner.
    Jan 2005
    San Francisco
    Great write up, thanks for the quick response! I have have to get these done at some point! BTW, where did you get the amber blinkers from? Also did you seal them with anything onto your fender, I realize there are clips, but was curious about water proofing!
    Mar 2002
    NY
    I got them from subydude for $80 shipped. Not cheap by any means but it's a great mod IMO. No sealant used at all. Even side turn signals don't have sealant.
    Registered User Jje121's Avatar
    Jan 2005
    Fitchburg, ma
    Looks good, and nice write up...
    New England F4
    Bugeye Mafia
    2004 GMC Sierra 1500
    03 Subaru WRX (SOLD)
    01 CBR 929 (SOLD)
    Quote Originally Posted by blarg
    nothing funny about stubble on the man-marbles.
    Registered User LIV 2 RLY's Avatar
    Jun 2006
    Central NJ/ Bethlehem, PA
    Any idea if these will fit on an 06 WRX? Are the fender contours the same? I think I am going to order a set up! They look great.
    Hawk-Eye alliance #052
    I'm also into photography!
    Check out my photos: My Flickr
