DIY 04-05 to 06 tail light swap
Results 1 to 10 of 10
This is a discussion on DIY 04-05 to 06 tail light swap within the Exterior and Appearance forums, part of the Tutorials & DIY category; Ok first off this is so easy as to barely merit a tutorial, but seeing as how I'm bored... First ...
    Registered User wherethefmi's Avatar
    Aug 2006
    Fort Hood TX
    First things first you need the parts to do the swap, namely the desired year tail lights, I got mine off of a buddies 04. Next you need a flat head screwdriver, or some thing to pry the carpet liner clips.
    Infantry leads the way
    Aug 2006
    Fort Hood TX
    ok now that you got those clips off you have some nuts to get off, they are probably 10mm but I used needle nose pliers, any way on the 06 model mine anyway had a black plastic clipc hiding one of the nuts on the passenger side it's the furthest nut from you.
    by the way I forgot to circle them but there's a plastic clip holding the tail lamp assembly in it's flat, if you look on the passenger side it's white and on the drivers side it's black be careful cause they seem kind of fragile, so be firm but gentle, push them out and back as you gently pull on the tail lamp.
    Aug 2006
    Fort Hood TX
    you will also need to disconnect this wiring harness it's a direct swap between model years.
    Aug 2006
    Fort Hood TX
    put everything back on in reverse order and you're done.
    becareful there's a foamish thing between the metal and the tail lamps don't rip that and make sure to line all the bolts and plastic bits that were poking thru before
    here's the before and after, I did this while doing my laundry at the laundromat, took me 5 mins to remove mine and 15 mins to wait on dude to remove his. have fun the after shot kind of stinks cause its dark and I like my car that dirty
    Registered User BlueCamel's Avatar
    May 2005
    Smithfield,RI
    is it the same with swaping for 2007 tail light into 2005
    Aug 2006
    Fort Hood TX
    yeah it should be, the only ones that are different is the 02-03 cause they are shaped different.
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    I know this is super super old and I am necro'ing it but, I have a question. I know the swap is a direct fit and the harness just plugs in. My question is about the placement of the lights. On the 06-07 lights the blinker is on the bottom inside circle part and on the 04-05 the blinker is on the top. When swapping the lights how is this corrected? Do the wires reach the correct holes?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    The bulbs are in different place but the harness will work no problem. I've had 03, 04, 06 and 07 tails on my car and they harness for 04 will work with 04-07 with a little bulb moving
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
    Nov 2011
    North GA
    Cool, so the wires will reach without me having to splice in extra?
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Apr 2009
    CO
    definitely
    Mods
    Pics
