2016 Limited Fog Light Upgrades?
Results 1 to 15 of 17
This is a discussion on 2016 Limited Fog Light Upgrades? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Trying to decide the best upgrade. I'm leaning towards 55w HID's. Any opinions why this should not be done? Better ...
    Sep 2015
    I'm leaning towards 55w HID's. Any opinions why this should not be done? Better choices?
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    subispeed has direct replacements. Replaced the housings and everything for a reasonable price.
    Jan 2012
    New Jersey
    It shouldn't be done since you would be putting HID in a reflector. Either get real projector fogs or go with something like this.
    Subaru WRX STI XB LED Fog Lights - High Performance Fog Lamp Upgrades - The Retrofit Source
    CFLip2x 2012 WRB WRX Build
    Sep 2015
    Quote Originally Posted by cflip2x View Post
    I had those same fogs in my Focus ST, very nice pieces. If you keep your eye on the "closeout" section of TRS, they will come up occasionally as B stock. Both my friend and I purchased these (his for a 15 STI) and they showed no visible imperfections. A steal for the 70 bux we paid! As far as light output, they matched his factory LED low beams almost perfectly.
    Hope that helps!
    SQ
    Feb 2014
    NJ, USA
    Everyone is raving about the Morimoto XB LEDs and housing.
    It's a direct pug-n-play.
    I will be going this route.
    Nov 2015
    Baltimore, MD
    I have been looking into adding a custom LED strip or a plasma light, but was told by a shop north of Baltimore that you have to cut apart the fog lights as they are not bonded like the headlights are; they were gonna charge me $350 to do the pair. Any of y'all have knowledge on this? And plasma vs LED strips?
    We choose to die on our feet , rather than live on our knees!
    ΜΟΛΩΝ ΛΑΒΕ
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    I have the OLM LED Direct replacements from SubiSpeed, they're nice.
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    I Drink & I Know Things JaySin's Avatar
    Mar 2008
    Detroit Metro
    May be a stupid question, but does replacing the fogs affect the steering responsive feature?
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    Quote Originally Posted by JaySin View Post
    Is this a new feature on the 16's?
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
    Mar 2008
    Detroit Metro
    Quote Originally Posted by Goose42 View Post
    Yes. It comes with the Eyesight system.
    From the Subaru media release...the description:
    "Models equipped with EyeSight also come with Steering Responsive Fog lights. This feature (which works when the fog lights are turned off) activates the left or right fog light independently, depending on the vehicle speed and steering angle, to provide enhanced illumination in the direction of the turn. The fog lights are pre-aimed for maximum coverage in corners."
    edit: clear as mud, right?
    Jun 2014
    PNW
    ^ Crystal creamy!
    Journal-
    Nov 2015
    Baltimore, MD
    Saw red circular plasmas (mayyy have been LEDs, was at a distance where I couldn't tell but LOOKED like plasma rings) on a WRX/STI a few weeks ago...
    BADASS
    ...and they HAD to have them custom made.
    ΜΟΛΩΝ ΛΑΒΕ
    Registered User ConBroMitch's Avatar
    Oct 2014
    On a dock by the bay
    Read: Daniel Stern Lighting Consultancy and Supply
    It's your choice to upgrade the lights. But as cflip said, a HID in a halogen housing is not only bad for you, its bad for other drivers on the road with you. You will actually see less with that setup.
    Too bright of fog lights and it will create too much foreground light, which will reduce the distance you can see.
    "Straight roads are for fast cars, curvy roads are for fast drivers." -Colin McRae
    Registered User 15WRBlue's Avatar
    Dec 2014
    Near Lansing MI
    HID for fog lights is not a good idea because you don't want to be having them go on/off repeatedly as would happen in switching between high and low beams when the fogs turn off with high beams on. Different halogens or LED bulbs make more sense.
    Ryan
    '15 WRX Premium -- Sunroof, short throw, upgraded lights (SubiSpeed LED DRL boomerang, OLM HID 5000K low-beams, OSRAM 5000K high-beams), TapTurn, STi Wing, 20% Tint
    Other current: '92 Stealth RT/TT, '07 Avalanche LTZ
    Previous: '04 Saab 9-3, '02 WRX, '94 3000GT SL, '91 Eclipse GSX, '82 Porsche 931 (924 turbo), '79 Saab 900T, '81 Mitsubishi Starion, '80 Triumph Spitfire, '74 Saab Sonett III, '72 Opel GT
    Nov 2015
    Baltimore, MD
    Quote Originally Posted by 15WRBlue View Post
    Valid point good sir knight, valid point
    ΜΟΛΩΝ ΛΑΒΕ
