-Hood Pins- help, please
Results 1 to 15 of 19
This is a discussion on -Hood Pins- help, please within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I'm trying to find a set of hood pins for a 2007 STI that look as close to the Hotchkis ...
    Vez
    Vez is offline
    Registered User Vez's Avatar
    Apr 2006
    Near Philly, PA
    I'm trying to find a set of hood pins for a 2007 STI that look as close to the Hotchkis (Hotchkis® 1760 - Hood Pin Kit) in both quality and appearance, that I can find.
    I am looking for a silver/brushed silver/gray set which uses a lanyard. I know there are other options...Aerocatch, locking pins, etc., but those are not what I'm trying to find. I looked at the Spectre, Daystar, Drake, Mr. Gasket, and Moroso, but none of them meet the criteria. I also don't want a cotter pin, I'd like a thick, pin like the Hotchkis or Drake pins. If I can find that AND have it lock, even better, but none of the locking pins I've seen need a lanyard, and I'm specifically looking for that.
    Am I chasing a non-existent set of hood pins? Even if I would be crazy enough to buy the Hotchkis for the ridiculous amount they charge, does anyone know if the Universal Kit will fit my car?
    Thank you.
    Hawk-Eye Alliance #081
    I'm the only person born a Pirate and trained as a Ninja; I sometimes don't get along with myself..
    2007 UGM WRX STI Ltd. #081/800
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Why do you need them?
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    lit fam XJman's Avatar
    Feb 2015
    At work
    If it isn't just for looks and you need them as part of a regulation for a track local to you then ask there as they will probably have tons of options or know what works best. If you are thinking about them because of hood flutter consider jeep has side latches and a center latch and the hood will still flutter bad enough to startle you at times.
    All? NO ALL!
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Thanks for your posts, suggestions, and advice. It really doesn't matter why I need them, I asked because I was hoping someone is able to answer my questions. While I appreciate everyone trying to guide me, I'm really just looking for answers to the questions. Thanks, again!
    Registered User GT800's Avatar
    Jan 2014
    Buy whatever pins you like then buy lanyards they sell them separately and you can get nice coated ones that dont scratch.
    Jan 2014
    The drake ones work very well though i had a pair on my gt500
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Thank you.
    Sep 2013
    WV
    WHY you need them would sort of guide our suggestions, some are for lucks, some are for function, so yes, it did matter why you needed them.
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    I respectfully must say you are simply wrong; it does not matter why I want them to answer my questions. I know what I want and I asked if there is a product which matches my description, nothing more.
    While I appreciate your attempt to make sure I have the right product for my purpose, I do not need that. I don't claim to be a Car Guru by any means, but this isn't my first rodeo, either, which is why I phrased it so explicitly. I know the plethora of opinions and flames that follow hood pin questions (along with BOV, EWG, etc. etc.).
    To avoid posts like these, asking me WHY and offering other options, I tried to be as specific as possible, asking straight-forward questions as not to waste anyone's time. Please read the post again.
    I asked if the hood pins I described exist or not. I also asked if there were anything that resembled my description. If you could answer these questions, that would be great. If you can't, then I appreciate you taking the time to read the post and trying to offer help.
    Feb 2015
    At work
    It matters because if you have to use them to hold your hood down and we recommend one to meet your needs based only off looks and not quality your screwed. I've seen several crap sets fail and send a hood into the windshield.
    All? NO ALL!
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Yes, I understand this.
    I asked a question. I am looking for an answer which provides me with this information. Ask question, (ideally) get answer. No one needs to know why I'm asking the question to answer it; it's irrelevant. Pretend it's the missing set in my collection if it'll make it easier to provide the information I asked. I understand people want to give advice, and at times it's warranted. This is not one of those times; I did not ask for it and have repeatedly and respectfully tried to make that clear. It's ones and zeros. Either, you can answer it or you can't.
    Feb 2015
    At work
    Look what part is it you want to match, the black hood clips? Most every set I've ever seen looks the same, if you want the fancy design on the protectors I've not seen one exactly like that. Some are just flat. I believe its ring brothers that had a set that looked similar and you can get in black as well.
    I only asked the purpose because if you were using them for function and you get a crap looks only kit you'll be back crying because your hood launched.
    All? NO ALL!
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Thank you for the lead. I'll check into Ring Brothers
    Feb 2015
    At work
    Also look into ones listed for other vehicles, mustangs, camaros, etc. Typically you can make non universal kits work because they tend to work in similar ways and you just mount them differently.
    Now that there is a lead, good luck. Remember cheap, fast, reliable pick two.
    All? NO ALL!
    Vez
    Vez is offline
    Apr 2006
    Near Philly, PA
    Thank you, again, for your help; it's appreciated. Have a great weekend!
