Whats the technical nomenclature of these front end trim parts?
Results 1 to 6 of 6
This is a discussion on Whats the technical nomenclature of these front end trim parts? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Was wondering if anyone knew what the proper Subaru nomenclature is to these parts. I'm trying to find them but ...
    Jan 2015
ID:	192785Was wondering if anyone knew what the proper Subaru nomenclature is to these parts. I'm trying to find them but I can't whatsoever. Anyone know by chance?
    The red arrows are pointing to the two trim pieces in question.
    '09 silver WRX base sedan. Stock-for now...
    Jan 2015
    Anyone? Need some technical nomenclature.
    Jan 2012
    New Jersey
    fender liner
    2012 WRB 4DR | SPT Exhaust | Cobb Short Throw | Rally Armour | WC Lathe Werks Custom TI Knob | Kartboy Bushings | Stoptech Pads & Brake Lines | JBK Elements DRL | STI HID Retrofit | XB LED Angel Eyes | GrimmSpeed Lightweight Crank Pulley | Perrin Cold Air Intake
    CFLip2x 2012 WRB WRX Build
  5. #4
    Jan 2015
    For both of them?
  6. #5
    Jan 2012
    New Jersey
    you could try to order the deflector but I dont know how bad yours needs replacing. Though if you need the front part as well you need to get the entire fender liner around $40 off of ebay just make sure to get the right part number.
    http://www.subarupartsamerica.com/pa...iagram=7592110
  7. #6
    Jan 2015
    Cool, thank you! I was looking but couldn't find the area within the parts manual online. Some are easier to navigate than others. Thanks again.
