2012 Hatch STi Headlights in 2013 WRX Sedan ???
Results 1 to 2 of 2
This is a discussion on 2012 Hatch STi Headlights in 2013 WRX Sedan ??? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I've searched around and cant find anything exact.. I have a 13 WRX sedan, a friend has a 2012 STi ...
    Registered User nosoupfoyou's Avatar
    Jan 2011
    Denver, CO
    I have a 13 WRX sedan, a friend has a 2012 STi Hatchback.
    The STi is being parted.. can I swap headlights with him and make this transition pretty simple?
    What will my process be for the headlight up/dwn leveling be?
    Can he make my WRX headlights work in his STi so that he can trade in the car after we swap?
    ...I'd hate to get hours into this tear down and swap if it cant be done or someone has some insight before we attempt this. Thanks !
    2007 UGM WRX STi - Limited 65k
    PSN : MileHiTattoo
    facebook.com/paul.berkey
    Jan 2012
    New Jersey
    the only thing that may not work is the leveling motor but i believe it should be fine. If not the only thing you may need is a relay to power the HID's.
    2012 WRB 4DR | SPT Exhaust | Short Throw | Rally Armour | WC Lathe Werks Custom TI Knob | Kartboy Bushings | Stoptech Brake Lines | JBK Elements DRL | STI HID Retrofit | XB LED Angel Eyes | GrimmSpeed Lightweight Crank Pulley
    CFLip2x 2012 WRB WRX Build
