2015 WRX/STI LED conversions Interior & Exterior
Results 1 to 15 of 24
This is a discussion on 2015 WRX/STI LED conversions Interior & Exterior within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I posted this in another thread but thought it deserved its own...... I replaced just about every bulb in the ...
    Registered User Kirk's Avatar
    Jul 2014
    Long Island, NY
    I replaced just about every bulb in the car with LEDs from superbrightleds.com. Heres a run down of all the PNs from there site:
    DRL (2) - HB3-WHP28-DRL
    Turn signals (4) - 7440-A45-T Amber
    Reverse lights (2) - WLED-WHP10 Cool White
    License plate (2) - WLED-WHP5 Cool White
    Dome light (1) - 3022-CWHP4 Cool White
    Map light (2) - 3022-CWHP4 Cool White
    Trunk light (1) - WLED-WHP5 Cool White
    Vanity light (2) - 3710-CWHP3
    Flasher for turn signals - CF18-08 8 Pin Black Toyota Flasher
    Do not try to install 7440-A3W-G for your turn signals....they will not fit through the hole in the housing. I found this out the hard way and had to return them.
    The vanity lights needed to be somewhat forced in because the diameter of the bulb is slightly larger than the stock bulb. They work and stay put once you get them in there, but it requires a little force.
    I didnt change anything with the fog lights... I dont really care for the overly bright and excessive headlight look. The LED headlights are plenty bright enough (almost too bright). Subiespeed sells an OLM fog light kit that replaces the entire housing/lens.
    Provided by Rainking:
    Bulb Types:
    High Beam Headlight: HB3 (9005)
    Low Beam Headlight (w/out LED headlights): H11 (H8, 881)
    Parking Light (w/out LED headlights): W5W (168/194)
    Front Fog Light: H16 NOTE: Owners manual is WRONG. 2015 WRX & STI use PGJ19-3 base as opposed to the 5202/9009.
    Front Turn Signal Light: WY21W (7440)
    Front Side Marker Light: W5W (168/194)
    Rear Turn Signal: WY21W (7440)
    Backup Light: W16W (921, 955, T15)
    Rear Side Marker Light: W5W (168/194)
    License Plate Light: W5W (168/194)
    Cargo/Trunk Light: W5W (168/194)
    Map Light: DE3175
    Rear Dome Light: DE3175
    Visor/Vanity Light: 6614/6614F 6641/6641F NOTE: Owners manual is WRONG. Visor/Vanity Lights are 29mm fuse-style bulbs
    Hopefully this can help whoever is looking to replace their halogens with LEDs.
    15' WRX Limited - Sold
    Aug 2014
    Nice write up, very useful. If you get a chance you should post some pics, would love to see how this turned out. Especially if you have before/after.
    Jul 2014
    Long Island, NY
    I dont have any before pics but I can try to take a vid of all the lights on and flashing
    Apr 2014
    Awesome guide man! Thank you 1000x for posting this!
    Jul 2014
    Long Island, NY
    Quote Originally Posted by BarryBostwick View Post
    Quote Originally Posted by VelociReX View Post
    Sure no problem guys. Im glad its helpful and its being utilized.
    I still havent had a good opportunity to make a quick vid of what it all looks like..... Ill get around to it soon
    Registered User Tox_Boy's Avatar
    Aug 2014
    thanks for the write up very useful.
    I just got in some of my LEDs in. holy cow those vanity lights are super bright.
    Registered User Sanala's Avatar
    Apr 2012
    Colorado
    Has somebody made a similar guide for 2012 and similar WRXs and STi's?
    Sep 2014
    Hey guys if you're looking for good custom equipment for your car, check out redlinegoods.com. They did a great job on my boot and now it matches the red stitching in my 2009 WRX. Check out some of their work
    Apr 2014
    The vanity light 3710-CWHP3 is discontinued. Do you know what else I can replace it with?
    Registered User ebautis's Avatar
    Jan 2015
    Baltimore, MD
    Nice! Thanks for the info, will definitely be using this soon.
    Mar 2015
    Great info. Just got them in too.
    Thanks
    Mar 2015
    Sorry for the bump, but I feel it fits here. I just installed the Subispeed Tail as Turn relay. Everything works perfectly, except when I install a 7440 LED into the rear turn signal, it doesn't light up. I tried 2 different LEDs, and tried rotating them. With the normal bulb in the plug, it turns on when I put the reverse lights on (as it should), however the LED's don't.
    I'm guessing bad batch of LED bulbs? I don't really have any other way to test them
    Mar 2015
    Cool TAIL AS TURN QUESTION
    Quote Originally Posted by D3luxe View Post
    Your LED's are fine.
    with the tail as turn relay you must replace the reverse bulb with an LED if you want to splice in your "old" turn signal to it.
    basically 4 LED's are needed. Two 7440 bulbs in white and two 921/T15 bulbs in white.
    Registered User Justchillin's Avatar
    Apr 2015
    Wichita KS
    Do you have to have any certain type of LEDs when swapping the halogens? I've heard of some LEDs melting and/or causing alarms on the dash? I want to switch as much as I can (interior and exterior) to LEDs but not if they're gonna cause problems.....
    sly
    sly is offline
    Jun 2015
    Update: The vanity lights you have listed do NOT work. They are too large for the housing. I got some for my 2015 WRX and the bulb is too long. It actually overhangs the socket and almost shorts out another line. The vanity light needs a 29mm diameter lamp and these are 37mm. I didn't see a 29mm LED light on superbrightleds.com but Amazon sells one by a company called Genessi. They are an exact fit.
