Rally Sport mudflap installation
Results 1 to 14 of 14
This is a discussion on Rally Sport mudflap installation within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; OK before I order some Rally Sport mudflaps I wanted to get an idea of the process. It looked not ...
    Registered User grendels_wrx's Avatar
    Aug 2013
    Northen, VA
    OK before I order some Rally Sport mudflaps I wanted to get an idea of the process. It looked not too difficult but maybe easier if you get the wheels off. Other than a couple the factory fasteners not getting reused does the car need any modifying, cutting, etc etc? I want a pretty simple bolt on thing and the video makes it appear so. But just wanting to get an idea. The rear ones look a bit tougher as there's fasteners near the exhaust.
    2013 Black STi Limited sedan
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    I've installed them with my wheels on it's a pain in the arse but still possible!
    Trust me when I say they protect your paint and keep your body clean I have a long dirt/gravel driveway so they save my car countless scratches and I've been lowered to the point where the rear mud flaps drag on the ground and show no wear only black from the asphalt.
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
    Aug 2013
    Northen, VA
    Man on man Subaru make some factory mudflaps! The part in the video where you have to pull on the lower bodywork and all... Doesn't look fun.
    Just noticed in your videos you've got my car! Get out of my car!
    Thanks for your videos. Was thinking about adding the Homelink mirror to my car and also the extended armrest.
  5. #4
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    I've installed mudflaps with and without the wheels mounted (wheels mounted on a 2011, wheels off on my 2006), easy enough with a ratcheting 90 degree screwdriver, though some parts may be better served by taking the wheels off. Granted, I went well above normal install when I put mine in my GD since I did end up ripping off the rears (backing into curbs and those cement things in parking spots started it, mudding finished the process) when I had the 2011 WRX. Mine are quite strongly mounted now with riv-nuts and bolts, shouldn't go anywhere.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/...ps665d9b9d.jpg
    Always dirty, never scurred......
  6. #5
    Registered User anxiouz's Avatar
    Aug 2010
    So Cal
    I had installed these on my 11 and don't remember it being difficult at all. IIRC separating the panels was not a big deal. You just need one of those screwdrivers that has a 90' bend in it because with the wheels on you only have like an inch of gap to work with.
    Loosen the panels plastic screws and its easy to pull them apart.
    Steve // 2010 Cadillac CTS-V // 2011 WRX hatchback (SOLD)
  7. #6
    Jan 2012
    New Jersey
    Rally Armor :P
    easy enough just watch the videos and take your time.
    And this is what Anxioz is talking about
    or you can a ratcheting handle and use bits
    CFLip2x 2012 WRB WRX Build
  8. #7
    Registered User Goose42's Avatar
    Jun 2014
    Portland, Oregon
    I love RA flaps, my third car with them, first Subie. It took me just shy of an hour, wheels on.
    Drive like hell, you will get there faster!
    2015 WRX COBB Surgeline Stage 2 Pro Tune
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
  9. #8
    Aug 2010
    So Cal
    Yep, that's the screwdriver I meant. I got a set of 5 of the first one for like $3.
  10. #9
    Feb 2011
    El Paso, TX
    The second one is what I'm talking about. Much more useful than those angle ones.
    Build Thread
  11. #10
    Aug 2013
    Northen, VA
    Quote Originally Posted by cflip2x View Post
    Rally Armor :P
    Heck never knew that existed. Could have come in handy in the past. Thanks. So basically I need this if I want to leave the wheels on?
    Did you intentionally spell RallyArmor the british way and include a space in your signature?
  12. #11
    Jan 2012
    New Jersey
    Sorry auto correct 😁 you don't need it but it helps you could bend the bracket a little and use a really stubby screw driver or a screw driver on a leather man double sided bit and pliers. You can even attach that one point first on the rear mudflap bracket. But again such a simple tool you can pick up at harbor freight or the impulse buy section of your logs auto store.
    Sent from my SCH-I545 using Tapatalk
  13. #12
    Registered User fireguy220's Avatar
    May 2014
    Akron, ohio
    I just installed mine on my 13 wrx and it wasn't bad , did it with the wheels on with no issues , just turn them the opposite direction of the side youre installing on. I used a ratchet with a driver bit and had no issues the rears are a little confusing getting the bracket the correct way. Other than a few small things they installed pretty easily. Pulling the trim off wasnt bad at all its like these cars are all snapped together anyways so it was easy pulling off and replacing. Like they said just take your time and it won't be an issue
  14. #13
    Aug 2013
    Northen, VA
    Quote Originally Posted by fireguy220 View Post
    Thanks. I assume no need to jack up car?
  15. #14
    May 2014
    Akron, ohio
    Nope did it in the driveway in about an hour the first side you do takes a bit longer but the other side goes pretty easy
