Custom license plate delete
Results 1 to 15 of 20
This is a discussion on Custom license plate delete within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Does anyone have any info on making custom license plate deletes? Either through a website or info on how I ...
    Registered User RottenZulu's Avatar
    May 2014
    Does anyone have any info on making custom license plate deletes? Either through a website or info on how I could do it myself?
    Any help would be appreciated 😊
    Thanks in advance!
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Well it depends on what you are talking about. Do you mean the front license plate relocator? If so, I would recommend the Grimmspeed one, its the one that I have, and I love it! It allows you to move your license plate around in dozens of different positions to give you the look that you want. Perrin also makes one, but I do not like it as much because it does not give you the option to move it around in different locations. Here is a pic of mine:
    Now if you mean the plate that covers the holes where the license plate screws into your front bumper, there a lot of different options. Perrin, grimmspeed, cobb, etc. all make one. I have the Perrin one. pic:
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    May 2014
    Quote Originally Posted by WRX-maniac View Post
    I'm talking about this but I wanna make my own.
    Nice ride btw 👍
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    If you don't have a shop that you can work metal on your own (this would be a very easy piece to make if you did, but I don't think you would be asking us if you did), then there are a few companies that might be able to help you out. I am pretty sure that Kartboy does custom engravings (at least i know they CAN), and if you ask they would probably do it for you. Lathewerks does this as well, and I am sure he would have no problem doing a simple plate delete. You will be paying a hefty price for these though. You might just swing into a local machine shop and see if they could fab one up for you.
    Jan 2012
    New Jersey
    Draw one on a PC and have someone 3D print it
    CFLip2x 2012 WRB WRX Build
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by cflip2x View Post
    Most 3D print plastics don't hold up well to UV and heat, since most printing technologies extrude hot plastic out of a nozzle (like a glue gun), and higher end machines will UV cure it after extrusion. This inherently makes them susceptible to degradation in an outdoor environment, although it would look nice for a while.
    Metal printing would be ridiculously expensive compared to laser cut or water jetted sheet metal. If you want metal, your best bet is to find a water jet shop (typically lower cost than laser, and good enough resolution for what you'll need), but you're still looking in the $150+ range since it's a one-off, and most shops have programming fees for setting up the first CNC cut. Obviously, the more you buy, the cheaper they get, since it's easy to duplicate the part once programmed. You'd probably also want to powder-coat it, for durability.
    Another option: my wife could make you a custom die cut vinyl for that space. Just get a flat image file of what you want, and it would be die-cut out of automotive-grade viynl, which is UV resistant. It will hold up for years of abuse, even with car washes/road grime/extreme weather/etc.
    2007 Outback 3.0R wagon
    MTM
    MTM is offline
    Registered User MTM's Avatar
    Feb 2014
    NorCal
    I can cut pretty much anything you want and Powder Coat it. Then you could add a decal or whatever. I could cut out letters but that may be a little to small since we have a CNC plasma not laser.
    Registered User Sal.LV93's Avatar
    May 2014
    Las Vegas
    Check out @billetworkz on instagram and they have a site too. Idk if he does custom but lots of the deletes look good.
    Sent from my RM-820_nam_att_100 using Tapatalk
    May 2014
    Quote Originally Posted by Sal.LV93 View Post
    Thanks man I've been looking for something like this!
    Registered User soloz2's Avatar
    Jan 2011
    Western NY
    Another option would be custom carbon and vinyl. I ordered a carbon fiber delete for him and hope to get it soon.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Current Rides: 05 Outback XT 5MT & 14 Forester XT Premium
    Past Subies: 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon
    Registered User Paragon's Avatar
    Nov 2014
    Silicon Valley
    Registered User Infamouszoltan's Avatar
    Jun 2014
    Salt Lake City, UT
    I used billetworkz and i love mine!!
    When did we stop being who we want to be, and start being the person the world told us to be...
    Stink Eye Mob #801
    Instagram: Infamouszoltan
    InfamousZoltanSTi
    Nov 2014
    Silicon Valley
    Wow, that look amazing!
    Jun 2014
    Salt Lake City, UT
    Thanks!!
    Check them out.
    They are super easy to work with!
    Stink Eye Mob #801
    InfamousZoltanSTi
    MTM
    MTM is offline
    Feb 2014
    NorCal
    lazer... jelly.
