Hella horns not working
Results 1 to 15 of 15
This is a discussion on Hella horns not working within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Hey guys, something weird is going on in my car... i installed the hella horns around a month ago and ...
    Registered User WREX8's Avatar
    Mar 2014
    Bergen County
    Hey guys, something weird is going on in my car... i installed the hella horns around a month ago and all of a sudden they stopped working... but the funny thing is that my car is now using a different horn which i have no clue where it is... i know this because i even unplugged the hella horns completely and the other horn was working. so my question is.. why arent my hella horns the ones that are used when i honk...???
    Palmyra, NJ
    Sounds like you did some weird wiring that didn't disconnect your stock horn.
    Or its possible you unplugged one hella horn, and only the other is going off. Just trace back over your wires and make sure they are still in tact. Also make sure you don't have any blown fuses.
    Registered User brucewayne's Avatar
    Mar 2014
    sayre, pa
    There is one stock horn left near the passenger side tire when you remove the stock horn from the front.
    2014 DGM Sedan
    Stink Eye Mob #228
    Mar 2014
    Bergen County
    i used the subi mods wiring harness and i checked both fuses.
    Mar 2014
    Newton Nj
    Quote Originally Posted by brucewayne View Post
    This. I removed both stock horns. Used subimod's wiring and haven't had a problem yet.
    Mar 2014
    Bergen County
    Ahhhhh how do i access the other horn? Cause the hella horns were working but then all of a sudden they stopped
    Registered User AFP520's Avatar
    Aug 2005
    NJ
    Did you buy it new or used? I was reading about the relay being used wasn't correct for the way the harness was wired. So as soon as you hooked it up to the battery the relay was energized and when you hit the horns they were still drawing power from the factory wires.
    '14 SWP STI
    Mar 2014
    sayre, pa
    I have the hella's on my wrx. Also I left the second stock horn in place. There really isn't a reason to remove it.
    2014 DGM Sedan
    Stink Eye Mob #228
    Jan 2012
    New Jersey
    I would check the relay and see if there is any corrosion on the terminals. I had to replace mine a few times since they got wet. I also used my own wiring harness.
    CFLip2x 2012 WRB WRX Build
    Mar 2014
    Bergen County
    I bought everything brand new, and yeah i didnt see a need to take off the second horn, should i contact subi mods with this? Or just go buy another relay? Also which would should i buy i dont mind spending the extra $$ if you guys know of a reliable water proof one
    Feb 2014
    PNW -WA STATE - rainy side
    I say get a meter and start checking circuits while a lovely assistant presses the horn button.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Jan 2013
    My experience with the Hella horns was not a great impression, for a while. I bought the Subimod harness and used their relay. 1 month or so after the install the relay went out. I then installed the relay that came with the horns. That lasted maybe 4 months. The sound was weak compared to what I expected. I had to leave one of the factory horns in case the horns stopped working. I was done spending money on these horns. I eliminated the relay and fuse cable that came with the harness. I connected the horn switch cable to the positive wires of horn, and ran the negative cables to the battery. The horns actually sound loud now.
    Feb 2014
    Quote Originally Posted by george023 View Post
    My experience with the Hella horns was not a great impression, for a while. I bought the Subimod harness and used the their relay. 1 month or so after the install the relay went out. I then installed the relay that came with the horns. That lasted maybe 4 months. The sound was weak compared to what I expected. I had to leave one of the factory horns in case the horns stopped working. I was done spending money on these horns. I eliminated the relay and fuse cable that came with the harness. I connected the horn switch cable to the positive wires of horn, and ran the negative cables to the battery. The horns actually sound loud now.
    That sounds really really weird. Basic DC electrics say something was wrong. Bad connection or something.
    Aug 2005
    NJ
    Did you buy new or used? There was a bad batch of harnesses that were not wired properly with the type of relay they included. There are diagrams floating around that should show you how it should go. I'm not sure you're getting full power to them if you're using the factory wires.
    '14 SWP STI
    Jan 2013
    I bought them new. I got the whole kit from Subimods.
