do LED tail lights need rewiring?
Results 1 to 6 of 6
This is a discussion on do LED tail lights need rewiring? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Hey guys, just wondering if anyone knows if it's required to do rewiring to switch from stock tail lights to ...
    Registered User SuperSonic12's Avatar
    Nov 2013
    Lehighton
    Hey guys, just wondering if anyone knows if it's required to do rewiring to switch from stock tail lights to the stock looking LED tail lights or if they just connect right into the stock connectors.
    Jan 2012
    New Jersey
    LED tail lights or LED bulbs? I swapped out my bulbs for LED bulbs and I needed to install a new flasher module otherwise I would need to wire in load resistors.
    CFLip2x 2012 WRB WRX Build
    Nov 2013
    Lehighton
    I'm wanting to ones like these where it's the whole assembly with the LEDs already in them
    Palmyra, NJ
    Ohhh...Ebay specials. I'd imagine the manufacturer could tell you whether you need to do any splicing or anything. I imagine there'd have to be some kind of harness or splicing considering you're no longer using a bulb, so the stock connector wouldn't work.
    Nov 2013
    Lehighton
    I take it you've come across this kind of tail light before, I did see them on eBay but saw them first on a few different websites. I don't think they are that bad looking, I mean they look just like the original tail lights and have red lenses where the brake light is, they just have LEDs instead of the standard bulb, kinda gives it a newer tech look I think anyway.
    Jan 2012
    New Jersey
    Depo 08 11 Subaru Impreza 4D Red Clear JDM LED Tail Lights Lamps WRX STI GE GH | eBay
    check out some of the pics it shows the "connectors" you could tap into the existing wiring
