Morimoto Xb LED Angel Eye Kit Install (2011 WRX)
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
This is a discussion on Morimoto Xb LED Angel Eye Kit Install (2011 WRX) within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I ordered this kit from OEM HID Projector Retrofit Parts & Service Specialists I Lightwerkz.net after seeing them on Mammal's ...
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    I ordered this kit from OEM HID Projector Retrofit Parts & Service Specialists I Lightwerkz.net after seeing them on Mammal's build thread Mammal's SWP 13 WRX (third times a charm) This kit is outstanding and I would recommend it to anyone wanting a new look to their WRX. Sorry in advance for lack of pics and technical info, I went in a little blind and am by no means an expert. If you have any questions, don't hesitate to ask. I will post more pics as requested.
    SO the install wasn't terrible, but it is very time consuming. There is a reason why the kit is only $55 but to have a third party like lightwerkz install it is considerably more. I have never done any kind of light addition or modification besides replacing bulbs before so it was a bit of a learning process. I have also never wired or soldered before. After searching the web extensively, I found a few links that helped, but it was mostly an unknown going in, so I was pretty nervous about messing something up. I am pretty OCD about setting things up in advance and having everything I foresee needing within reach prior to starting a project. Here's what I grabbed:
    -Pliers, in several varieties. Needle nose, angled needle nose, varying sizes of traditional, etc
    -heat-shrink
    -heat gun
    -electrical tape
    -cordless drill
    -drill bits
    -screwdriver...lots of em
    -gloves (for protecting lens/bulbs more than hands)
    -silicone
    -ultra thin wire
    -1/4" socket set
    -soldering gun+ solder
    The first step is to open the hood and begin removing the bumper. I chose to park on a set of car ramps for a more accessible work height (and I was glad I did) as you can see in the pic. Here's the link for the video I watched a quick reference. Honestly you can figure it out, its not hard, but watching the video first can prevent unwanted surprises.
    Remove Front Bumper Subaru WRX - YouTube
    I almost missed this clip for some reason, thought I would post a clear pic:
    These smaller clips are super easy to remove, but a PITA to put back in.
    Next remove the headlights. You dont need a video for this, its very straight-forward. There is a clip up top and four 10mm bolts holding the assembly on. Then remove the harness clip and a small plastic retainer piece. Use your hands for this, as its very fragile. Once I had the assembly removed, I watched this video on baking the headlights for separation and the necessary prep for this procedure.
    How to bake 2008-12 Subaru WRX STI headlight - YouTube
    The video makes this process look much easier than it really is. The assembly will not be hot enough to burn your hands (it didn't burn mine, although mine are pretty calloused and used to working on cars). When prying the assembly apart, be cognizant that the heat makes plastic malleable...which means you can scar it pretty easily. I inserted the screwdriver laterally instead of perpendicularly to prevent this from happening. I used a second flat tip to cut the adhesive as it stretched apart. Some tips:
    -TAKE YOUR TIME. I reheated mine 3-4 times after the adhesive started cooling. The adhesive is stronger than the plastic when not warm.
    -Be careful not to scar or stab the inside components with whatever you are using to pry with
    -Having a second pair of hands is very helpful. I pried while my wife cut the adhesive with a small flat tip
    After separating the assembly, I began mounting. I used TRS's advice and DIY video, and used wire opposed to adhesive, and I am glad I did. Here's that link:
    TRS Tips: How to Install Angel Eyes or Halos (xbALed, XB LED, SMD, CCFL) - YouTube
    Again, the video makes it look easier. This time it is mostly because you will be working with a much larger assembly and harder drilling angles. I used the thumb-tack method for starting the holes, and it worked nicely. I drilled the holes for the wiring on the BOTTOM of the bezel so that they couldn't be seen once the project was complete, as these will be the largest holes. I also removed the individual wires from the clip so that the hole would be smaller, and re-inserted them after running them through.
    Here's a pic illustrating exactly what I did.
    Here is the front. You can barely see the wire, even without the lens cover!
    I chose to wire my angel eyes into the parking lights, so I could have them off during the day if I wanted. The research I did steered me away from wiring them as day running lights (drl's), as they won't last as long, and you wouldn't be able to turn them off without nudging the parking brake up a bit. I am sure there is a better way to do this, but here's how I did it... I exposed a small section wire from the 12v supply and ground to the parking light (also the blinker light). The hot is the green wire, not the red. The ground is obviously black. If you wire it to the red it will blink with the turn signal (and stay off when no signal is engaged). I then cut the ends off of the light kit, stripped half an inch, and soldered them onto the parking light wires. Sorry I forgot to take pics of this process! But here is a pic that hopefully is helpful. If anyone has any questions, I can remove a headlight and post more pics; its pretty straightforward though. Make sure you cover everything with heat shrink/electrical tape!
    I drilled a small hole in the back of the headlamp cover for the wiring from this kit, then sealed it up with silicone. Make sure all holes are sealed up or you will get contaminants inside the assembly over time.
    That's pretty much it! Put everything back together, rinse and repeat.
    Jan 2012
    New Jersey
    Nice write up glad things worked out. I ended up setting mine as DRL but may consider putting on a switch. I also cut a small slit in the High beam boot and just fed my wires though that. You can also bake the headlights for 220 for about 15-20 min. This will also help to soften the old sealant to help use it again. Did you remove the amber reflectors?
    CFLip2x 2012 WRB WRX Build
    Jul 2013
    North Carolina
    Quote Originally Posted by cflip2x View Post
    I thought about putting a slit in the boot also, was worried the slit would grow with time and I would end up buying a new boot. I read a lot on Nasoic suggesting not to run as drl... I guess I am just not in a hurry to do this job again if/when they burn out
    Jul 2012
    Rocky Top
    Looks good! Nice write up too.
    Jul 2013
    North Carolina
    Quote Originally Posted by wreckingball man View Post
    Thanks!
    Aug 2013
    Baltimore County Md
    Looks good, I had a similar setup on my vw passat. I can't wait to throw these on my wrx.
    Registered User Mammal's Avatar
    Apr 2013
    Southern Vermont
    I just got your PM my dude! Nice write up
    Jul 2013
    North Carolina
    Quote Originally Posted by Mammal View Post
    Thx man, no worries! I thought about just doing the retaining wire just at 3 and 9, but I was paranoid the light would fall off
    Thanks again for the inspiration!
    Apr 2013
    Southern Vermont
    No problem dude! To answer your question though, I did use jb quick weld to hold the wire in place lol
    Jul 2013
    North Carolina
    I used these to secure the wires pretty tightly
    Then i put a little silicone on them to keep vibrations away. JB Weld is a little too permanent for me
    (although i did drill holes in my headlight housing lol )
    Apr 2013
    Southern Vermont
    Thats a nifty tool!
    hahaha yeah once you drill the housings you are committed lol
    Registered User Rich E dee's Avatar
    Mar 2013
    Imperial PA
    With the way you wired the angel eyes when exactly do they turn on? Do they stay on when the car is on? Do they come on when you unlock the car? Are you DRLs turned off so they stand out more when you drive?
    Jul 2013
    North Carolina
    Quote Originally Posted by Rich E dee View Post
    I wired them to run with the parking lights, so I didn't have to have them on. If I really want to run them w/o the drl's, I just pull the ebrake up slightly to disengage them. It's recommended not to wire these as drl's, although a lot (if not most) do it this way with no problems.
    Apr 2013
    Southern Vermont
    I tapped mine into the marker lights and disabled my DRL's. So whenever your marker lights are on the halos are too!
    If you don't disable the DRL's the overall look is just too much between the markers, DRL's and halos.
    Apr 2013
    Southern Vermont
    If you can locate your DRL relay in the fuse box under the hood, all you have to do is pull it out and you will see that there are 3 prongs closely in line together on that relay. I simply removed the middle prong with some needle nose wire cutters to disable the DRL's permanently. If you go this route and want your DRL's back, all you have to do is source another relay.
